BJRobinson Posted March 5, 2023 Share Posted March 5, 2023 Hi. I often get steps and steep angle changes in 3D polygons. I can sometimes get rid of it by adding vertices. But sometimes I cannot. How can this be avoided? Thanks. Quote Link to comment
mike m oz Posted March 5, 2023 Share Posted March 5, 2023 3D polygons are planar so need to have only three vertices. You need to either raise the 3D polygon ends in the centre of the image so they finish on the edge of the 3D polygon on the right or break the latter up into smaller triangles that join at the lower common point. Quote Link to comment
VIRTUALENVIRONS Posted March 5, 2023 Share Posted March 5, 2023 This might be something better remedied at the point of creation. Can you provide a little more info on how and what you are creating? Quote Link to comment
BJRobinson Posted March 6, 2023 Author Share Posted March 6, 2023 20 hours ago, mike m oz said: 3D polygons are planar so need to have only three vertices. You need to either raise the 3D polygon ends in the centre of the image so they finish on the edge of the 3D polygon on the right or break the latter up into smaller triangles that join at the lower common point. So contradictory to this VW video? https://www.google.com/search?q=vectorworks+3d+polygons&oq=vectorworks+3d+polygons&aqs=chrome..69i57j0i22i30l8j0i390.15088j0j7&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:81d919cc,vid:YbRW7-f-sJQ Quote Link to comment
BJRobinson Posted March 6, 2023 Author Share Posted March 6, 2023 20 hours ago, mike m oz said: 3D polygons are planar so need to have only three vertices. You need to either raise the 3D polygon ends in the centre of the image so they finish on the edge of the 3D polygon on the right or break the latter up into smaller triangles that join at the lower common point. I am creating a garden bed in this instance. Could be anything. I am clicking on existing geometry like bases of fences, edges of drives. etc to create the polygon. Quote Link to comment
BJRobinson Posted March 6, 2023 Author Share Posted March 6, 2023 20 hours ago, mike m oz said: 3D polygons are planar so need to have only three vertices. You need to either raise the 3D polygon ends in the centre of the image so they finish on the edge of the 3D polygon on the right or break the latter up into smaller triangles that join at the lower common point. But yes, creating many more simple polys might fix it. Just trying to not complicate things. Quote Link to comment
mike m oz Posted March 6, 2023 Share Posted March 6, 2023 The underlying 3D geometry of a non planar 3D polygon with more than 3 vertices will be triangles as shown in this Artistic Renderworks image. Quote Link to comment
VIRTUALENVIRONS Posted March 6, 2023 Share Posted March 6, 2023 Your original method would/could work, but you not snapping to points that are on the same plane. They may appear to be, but are not. There are many ways around this, but one from what you have described is to: First - Select the "3D locus" and put one wherever you want the edges of your garden bed to be. Essentially doing what you first did, but just put in the 3D points. Second - Then use Ccustom Selection>Type is 3D Locus" to select them all. Third - In the Object info box, set their "Z" to the same elevation. Fourth - Then pick off those points with your 3D polygon tool. Quote Link to comment
