I've been having trouble with the 'Create Similar Object' tool.
In a file originally created in 2021, it changes the attributes palette to appear to be the right line type, but then only puts down a similar colour and weight. The actual linetype is different.
In a file created in 2022, it will lay down the same line type, but not the same local scale as the original copied.
In either instance I still have to go back and use a normal eyedropper tool to transfer the desired properties to the new line.
Are there any settings to the tool that I have missed?
DSmith2300
thanks
3 answers to this question
