I have a window placed in a wall. The other windows in the project are functioning and appearing as desired, but this one includes a line from the wall extending into the window opening. It is part of the wall -- when I select the wall, this rogue line is also selected. If I remove the window from the wall, that section the the wall has no outline. In this particular instance, the casework (class turned off in screenshots) is there, so it's not noticeable, but I'd like to know what's causing it in case it happens elsewhere on another project. Any ideas what's causing this graphic issue or how to remedy it?
EmilyArch
3 answers to this question
