The Hamma Posted September 8, 2022 Share Posted September 8, 2022 I created the attached DTM from 3D contours but when I view it as a rendered solid it only shows the bottom faces and appears empty. Open solid DTM.vwx Quote Link to comment
Tom W. Posted September 8, 2022 Share Posted September 8, 2022 (edited) You have lots of very spread-out geometry + it's all very far from the Internal Origin i.e. 1000km... Move closer + all is fine: Edited September 8, 2022 by Tom W. 1 Quote Link to comment
The Hamma Posted September 8, 2022 Author Share Posted September 8, 2022 Thanks, I never remember that this is an issue. Quote Link to comment
zoomer Posted September 8, 2022 Share Posted September 8, 2022 5 hours ago, The Hamma said: I never remember that this is an issue. Objects far away from VW origin (more than about 4 kilometers) is always the reason for any kind of severe problems and failures in VW. This happens to so many users, not only new ones. So before you could even install a VW, you should be hinted by a large warning in EULA, that you shall not ever try to draw/import/place objects outside of the save drawing area. No, VW should even prevent the existence of any objects larger or out of its save drawing area. Just to not let users trap into that fact and avoid that negative experience that users will get one or more times in their VW career. 2 Quote Link to comment
