Tim P.
23 -
Reputation
0 NeutralPersonal Information
Location
Wisconsin
Thanks for the reply Benson. I abandoned the landscape wall tool totally, and just did the presentation for the customer using extrudes. Maybe the tool will work with the new 2012 release
I am having difficulty using the Attribute Mapping Tool on segments of a curving Landscape Wall. I'm wondering if the program doesn't allow the process and am wasting my time trying to do it. I am trying to get a texture to appear continuous instead of segmented.
Free Resources question (under help).
Tim P. replied to ADMTWO's question in Wishlist - Feature and Content Requests
Vectorworks is claiming to be a strong 3D product. Vectorworks Service Select has a collection of Videos and Webinars On Demand available, but we need more concerning the 3D Tool Set. It would be nice to know the advantages and limitations of each type of 3D object, and how each can or can not be edited. Thanks, Tim -
will VW 2012 finally have missing features?
Tim P. replied to Cadplan Architecture's topic in General Discussion
Hi Jeffrey, Do you think 3D PDF will be possible? -
Text on Plant labels is visible on screen but doesn't print
Tim P. replied to geoform's topic in Site Design
It seems if you use a common font like Arial, it will print. I have had to search for fonts that did not contribute to printing problems. -
The outlines that can be rendered around 2D plant symbols are associated with the "None class" in my file. If the line thickness is changed in the class and "Make All Attributes By Class" is checked in the Attributes pallet, the outlines appear to change in the "Edit Plant Definition" window's "Top/Plan Preview" box. The lines do not render differently in the drawing. Do other Vectorworks users have success changing the line thickness?
I have a similar question. Is it possible to change the line thickness of the outlines that can be rendered around 2D plant symbols? To clarify, I don't mean the Plants-Component-Outline Class.
Thanks for working on the GDI/font problem. One font bug that I just noticed is that exporting a drawing with italics to PDF will create a PDF without italics.
Try turning off GDI, and see if that helps. Many fonts will not display properly if GDI+imaging is checked on. I've been informed by Tech Support that it is not a bug and it is not on the list to be addressed in any patches.
Graphical Device Interface. GDI is a Microsoft Windows interface for representing graphical objects and transmitting them to output devices. GDI is similar to QuickDraw for Apple computers. In order to show transparency, GDI must be turned on in Vectorworks. I would like the labels on my plans to have a hand lettered look. Thanks Petri.
I've been informed by Tech Support that many of the TrueType fonts that I would like to use are not going to be compatible with VectorWorks. ("With fonts that are not standard or native to your operating system, some will work with GDI on and some will not. You may benefit from visiting the tech forums on our website and seeing what architectural fonts people are using in VectorWorks 2008.") If anyone knows of an architectural style font that works with GDI turned on, I would appreciate a response. Thanks!
How do you get the Plant Tags to appear in the Default font
Tim P. replied to cdavis's topic in Site Design
I've noticed that plant symbol tags display in different size fonts than the document setting, some are larger and some are smaller. This happens if the symbol is dragged from the Resource Browser. The font is the correct size if the plant tool is used. The drop down list in the plant tool scrolls so slowly that I prefer to use the Resource Browser. It is also more graphic, allowing thumbnail display of the symbol. Can the font size problem be solved with the Resource Browser? -
edit: DISREGARD The following actions result in a reportable crash. I wonder if this is a problem that is going to be fixed in service pack 2. (1) Double-click a plant symbol that has "Plant Shadows In Plan View" checked on. (2) Highlight the "Definition" button in the "Edit Plant" window. (3) Select "OK" DISREGARD... After rebooting the PC three times, I can not duplicate the problem. ??? go figure. Thanks Darrell.
Vectorworks 2008 crashes when plotting with image fills
Tim P. replied to josh3ber's question in Troubleshooting
The same behavior occurs with my HP9800 printer. Exporting to PDF results in missing text. Hopefully the files that I sent to bugsubmit@nemetschek.net can duplicate the problem on your labs computers. Let me know if you need more information. Thanks for showing that VW is committed to improving it's products. -
VW disappears. The printer feeds a sheet of paper. The printer driver (HP Photosmart 8000 Series (60.51.644.0)) shows no activity. Other programs run normally.
