cdavis
43 -
Reputation
0 NeutralPersonal Information
Location
Austin, Texas
Recent Profile Visitors
When exporting images the embedded worksheet (plant list) disappears. However when exporting to pdf the worksheet shows correctly. The drawing will print the embedded worksheet just fine. The Export Image File screen does not show the worksheet either.
This was solved by calling tech support. It was a bad custom workspace file.
In the design view with right view set I have created dimensions. When I view the viewport with the right view selected the dimensions disappear. I have all the layers and classes visible. The top view dimensions are visible in the top view viewport.
I checked that. There was only one class and it was visible.
Sometimes when I create a plant, shapes disappear within the object. See enclosed file. When I go to edit the 2D graphics of this plant the objects that had disappeared now are visible. They are visible in the Plant Definition window also. I have tried grouping and the entire graphic part of the plant disappears. I can copy and paste the 2D graphic into the drawing window and the internal objects are visible.
I am trying to create Callouts where the text will line up vertically on all of the Callouts.The end of the arrows are to the right of the text. Even with the Always Left-Justify Text box checked on the text right justifies to the vertical line I have created. I have tried the create from the text button and the create from arrowhead button to no avail. It always right justifies the text when the arrow and line are to the right leaving a ragged left edge of the text.
Custom Selection does not seem to select anymore.
cdavis replied to cdavis's topic in General Discussion
All of the layers are visible. With Show/Snap/Modify on Layers and Classes. -
In SP2, I try to select Plants using Symbols and select the Plant name. Nothing shows as selected. Not even in the Object info. I think it was working in SP1. I am using SP2 build 82613.
I tried to print with transparency. It would not print. I have talked to technical support on Dec 20th. and they said in order to print you have to have GDI turned off. They also said they would have this update available in a few days. Does anyone know when and where it will become available?
When creating a plant in Landmark if I type in the latin name when creating it the plant turns into a dot. If I leave out the latin name of the definition when creating and add it later the plant works normally. I have installed SP2 for XP.
Worksheet does not show when drawing is processed in Image Export
It does not matter what settings you use. If you export image from a design layer the worksheet will be visible, but using a viewport makes the worksheet disappear. This happens in all my drawings with worksheets. This function used to work several weeks ago. I reinstalled SP1 with no difference. It does not matter what the DPI is. I tried 72 and 300 dpi without any changes. -
The entire drawing will export except the worksheet part. Also, in the preview (on the Export Image File screen)with the Render or Wireframe button pressed the worksheet is not visible. The same drawing will export correctly using the PDF export. The file size exported on pdf is over 150 megs for a 22" X 34" drawing. Is this large of file size this typical?
I have created landscaping symbols and want to trade for others. All 2D and in plan view. Basketball goal, Playscape (3 station) with slide and climbing net, 3 tier round fountain, boulders, stepping stones. Email me at cody@theperfectview.com. Also, I have several dozen Central Texas plant and tree symbols.
