Hans-Olav
    712
Reputation
346 Spectacular
3 Followers
Personal Information
  • Occupation
    Architect
  • Homepage
    tst.is
  • Location
    Iceland
Recent Profile Visitors
  1. Yes, through the geolocate tool or survey point tool and then login:
  2. I think the problem is conected to esri. You need to log in to get map / satelite photo. There is a free user option available.
  3. I can confirm, it is working now! Thanks for the quick response 😘
  4. Hello @Marissa Farrell You helped me 5 years a go with this marionett. My project from 2020 will finally be realized but with changes and I have to redo some items. When opening the file in v2025 I get the following error: texturmynd-2025.vwx
  5. Thank you @Pat Stanford This solved our problem, so good to have you on the list, always helpful!
  6. We are experimenting with the graphic legend, I hoped it was possible to summarize each door type based on opening (swingHingSide) I can sort of get it with a long list, see below but I would have preferred Opnun: Left 7, Opnun: Right 8.
  7. Fabulous! Just updated and can confirm its working now
  8. I have tried architect workspace, design suite workspace, architect-BIM workspace and no-one have revit import option
  9. Its the same here, Greyed out "RevitImport not in Plug-ins folder" & "RevitBatchImport not in Plug-ins folder" messages and no Revit import options in the workspace editor. Its seems Revit Import is totally missing frim the instalation. I have tried repair and install manager saying nothing to repair @Dave Donley can you help?
  10. Im on a Intel Imac Ventura 13.6.7 My Cloud version is 13.5.2771
  11. There might be a possibility to use the Data Manager and assign a class or record to every HULLDEKKE to make it simpler to isolate or select them. I have only limited experience with the Data Manager so I can't really help
  12. Hei Stig Runar! I would try to set up a worksheet, searching for IFC and field values You would get a rows for every item and could the right-click each row to select the item.
  13. I would start with the purge command to see if some classes are imported but not used. Then you can choose the class you don't need and delete it, you get an option to replace it with some of the other classes.
  14. You can drag the tabs to separate each pane and have as many as you want open.
