199 -
Posts posted by MartinBlomberg
34 minutes ago, Gadzooks said:
This has been discussed numerous times and has had various solutions and guidance from the forum.
Just search tent
Thanks!
2 hours ago, JustinVH said:
We do not have this company in the shipped libraries. The only event frames we have are Aluvision, AV Drop, and for those on VW2024 Quest Events when the September Premium Library update gets released.
Aha ok, thanks! Any clue where I can find them by any chance? I thought they were a part of VW's earlier edition, or am I wrong?
Hi,
I've seen some people use beMatrix parts in their designs. I can't find the objects in VW.
Where can I find a library of these parts if not in VW? I'm on VW24.
Thanks!
On 4/22/2023 at 3:40 PM, Bill McGarvin said:
This is an old thread but are the BeMatrix panels mentioned here in the Vectorworks Library? Can't find them anywhere.
I'm on the same search. Any luck?
@DBruhnke That made sense! Now it works! Thanks!!
- 1
Thanks! It still doesn't work on my end. I've set the object to "Closed" and connected all lines.
I've also changed the fillet radius to several different sizes (I even tried that before without any success).
I must be missing something really obvious here...
Hi,
I must have forgotten something important because I can't fillet these polylines' edges.
Am I stupid or am I missing something? File for download below.
Thanks!
I found this out as well. You need to have the class you want to use for data tags active when adding data tags. In my case I had another riser class active and it pasted the risers from that class onto my sheet, which I didn't want. Took some time to figure this one out....
18 hours ago, Josh Schulman said:
You could make a symbol for 1’ deck, 2’ deck, 3’ deck and have the deck height on the symbol. Or you could make those symbols and have a data tag report back the symbol name.
If I create a symbol I can't use the stage deck tool any more right? I thought about that as well, but had second thoughts since I'd need a lot of symbols for different heights and combinations...
19 hours ago, Kevin Allen said:
couldn't you also use a Dara Visualization,and make all the 24" decks green and the 36" tall decks red?
I've thought about that, but I want to have it super clear what each risers' height is. I might end up doing both of them in the end 😃 Color and height info.
- 1
21 hours ago, markdd said:
Are you adding the tag to the annotation section of the sheet layer viewport?
Yes I am..
6 minutes ago, markdd said:
Yes. It makes a data tag that is now available in the resource manager. Just add it to the stage deck objects in the sheet layer viewport.
I must do something wrong because I only get a (!)-symbol... Any clue why this is?
15 minutes ago, markdd said:
A Data Tag is the way to do it. If you don't have one that's suitable, select a Stage Deck object and run the Create Data Tag command from the Tools menu. It's a fairly simple process that will go a long way to creating a finished Data tag that shows height.
Thank you! Can I batch-do this with every stage deck in the drawing, or do I have to make them one by one? I'd like this feature to be default and for the Data tags to be on a specific layer as well. Can I implement this at the time of putting the decks on the drawing?
Many thanks! Martin
Hi,
I'm trying to show my stage decks-heights on a sheet layer, but adding a linked text from a record doesn't work as far as I understand.
I tried to use the "Text Option" dialogue box -> activate Height, but that makes the text too small and doesn't align with the riser.
Any tip on how I can do this better?
Thanks!
On 7/27/2023 at 6:53 PM, Scott C. Parker said:
@MartinBlomberg I played with your file. Finding the "sweet spot" for attaching corners can be frustrating, but once found, the assembly works without having to do the rotating you mention. Making this easier is on our list of needed improvements.
Here's a video from my playing with your file.
Thank you!
- 1
18 hours ago, Mark Aceto said:
I do a lot of ground supported structures, so before I discovered that, I wanted to throw my computer at a wall. I feel exactly the same, haha! 😃
It makes sense but, as a best practice, it's not very well documented. For me, a lot of the confusion is that's not the sequence of how we're gonna build those ground supported structures onsite (typically a goal post, a tower, connect them with a horizontal, wash, rinse, repeat). I guess one has to think the other way around then..
BTW the other thing I'll sometimes do is put the towers (and ballasts) on a different layer (at least until everything is connected in the drawing. Just depends... Will that help the connection process somehow?
There were also few big improvements to BW in 2023 that allow for editing truss systems with much less aggravation. I don't own BW for the time being, but that's good news!
Many thanks!!
- 1
20 minutes ago, Mark Aceto said:
The workflow has to be:
- Connect all horizontal truss and CB’s
- Connect vertical truss
Think of the vertical truss as hoists (same order of operations to vertically support the horizontal grid).
Ah, that's a good one. I'll try this one out straight away 😃
Thanks!!
- 1
On 7/14/2023 at 1:57 PM, Scott C. Parker said:
Would you please post a sample file with the truss included? It'll be easier to help if we can play with what you're using.
Hi again! Would you by any chance have a clue what's going on? Am I just a rookie here or is something not really straightforward with vertical trusses? Now I'm working on a vertical LED GS system but every time I attach the truss to the base it flips upside down, and hence put the truss below the actual base plate. I'm thinking, might @jcogdell have a clue since you're the master of trusses 😃 ?
Many thanks all!
On 7/21/2023 at 3:37 PM, VIRTUALENVIRONS said:
Hi Martin,
I tend to stay away from Architecture as I don't understand the language, but the thread was interesting. As it finally evolved into 3D modelling, I understood what a Saddle Dome was. Anyway, lots of great information on this thread that points out the many ways to solve a problem.
I thought that the surface method was very slick and simple. I like slick and simple.
When I looked at Kevin's link to the company I noticed the outside edges were not planar for lack of a better word. I thought I would show another take on Surfaces.
So nice! Great stuff! Thanks!
@Kevin McAllister , @bcd and @markdd you guys are just the best.
So many thanks!!!
I really want to learn how to model stuff in 3D more and this info got me started. Warm regards!
Martin
- 2
2 hours ago, Kevin McAllister said:
Who is the manufacturer? Do you know the model?
Kevin
No clue about that unfortunately.
On 7/3/2023 at 6:22 PM, markdd said:
I think in general with referencing you need to be able to keep track of where everything is. Google Drive and Dropbox work well with referencing as long as you keep the files locally and don't allow the cloud drive app to make them "cloud only" after a period of time without use. I know Dropbox does that which has caused problems in the past although not with Vectorworks.
So no, as long as you know where they are, and use relative referencing rather than absolute, you should be OK. I don't use templates to hold anything other than the most rudimentary of settings as for me, they cause more problems than they solve!
I'm probably mega stupid now @markdd, but I don't really follow, so sorry. Do I reference the "Master Symbol" vwx-file inside the venue drawing I'm working on? Do I do that via the References-palette? Until now I've drag'n'droped the symbol I want to use from my symbol file, but then it just makes a copy. In my case I have a folder named "Customers" with all my drawings in. I also have a folder named "Symbols" with my Symbols.vwx in. I want all drawings inside my "Customers" folder to look for master-symbols inside the Symbols-file.
I wouldn't be surprised if you already answered this and that I'm just lost 😃
Many thanks!
/Martin
7 hours ago, markdd said:
Try this approach
Wow! Thank you so so much for helping me out! I’ll try this today! @markdd for president!
- 1
Light but no Light
in Rendering
Posted
Hi,
I have had an issue with this rendering since the start of the drawing. Same problem with VW22, 23, and now 24.
The lamp doesn't light up but there is still light somehow. It works sometimes, but mostly the lamp is black.
Any suggestions? Thanks! 😃
