Nikolay Zhelyazkov
Vectorworks, Inc Employee-
1,913 -
Everything posted by Nikolay Zhelyazkov
Hello @FBernardo, Make sure that in Page Setup you have set your page to be One Printer Page sized. Let me know if this helps. Best Regards, Nikolay Zhelyazkov
- 25 replies
- a3
- nottoscalewhenprinted
(and 2 more)
Tagged with:
Hello @Mickey, This should be fixed in VW 2019. If you are seeing the problem there, could you send me a test file? Thanks, Nikolay Zhelyazkov
Hello @Kevin Allen, The problem in your file is that there are many wall peaks created and they cannot be visualized. You could remove your peaks and fit walls again with greater curved wall fit interval (for me it worked with 5'). Best Regards, Nikolay Zhelyazkov
VWs 2019 Title Block - batch Renaming/renumbering Sheets
Nikolay Zhelyazkov replied to twhitwell6's question in Troubleshooting
I am happy to help 🙂 -
@twhitwell6, Do you have Auto Drawing Coordination checked in Document Settings? If so, could you send me a test file to see what is going on wrong? The TBBs should update when the sheet is renamed. -
Unfortunately, I do not think that this is possible for now, if you want to make batch rename of sheets. Maybe the fastest way will be to use the Organization Dialog. -
Hello @twhitwell6, The Sheet List report is only listing the Sheets you have. You cannot edit your sheets from it, as it is not using Database rows that allow this. Best Regards, Nikolay Zhelyazkov -
Raising the roof should be ok too I think.
It seems like your side walls that are directly under the roof are still above it and that is why the fitting is failing. -500 offset fixes it, maybe less than that could work too. Make sure you do not have walls that are above the objects that you are top fitting to, so that your fit does not fail.
@jwseas Did you move your walls a bit lower? I think that setting a bottom offset of -100 should get the job done. If not, simply select the wall, Modify->Move 3D->move by -100 Z.
@jwseas I think I found what is going on wrong. The bottom of your wall is intersecting your roof and that is why the roof is not counted as valid for fitting. You could move your wall a bit lower (it worked for me with -100 with Move 3D by Z). I have used Top Boun of Layer Wall Height. Let me know if this fixes your problem. Best Regards, Nikolay Zhelyazkov
Hello @jwseas, You could try uploading your file to dropbox and sending a link here or maybe try sending the file to me via PM so that I could look into it? Best Regards, Nikolay Zhelyazkov
Publish to print messes up the order
Nikolay Zhelyazkov replied to _James's topic in General Discussion
Hello @_James, I have looked into this for some time. I have noticed that you have a field in Sheet Data that has empty name, which is causing the naming schemes to be messed up (I think I did not see this before). Could you try deleting this field and then printing and tell me if you still have problems? Best Regards, Nikolay Zhelyazkov -
Hello all, We have received other reports about that and we are looking into it, but we do not have the certain steps to reproduce it. Does anyone have steps that reproduce this 100% of the time? Also, is this happening with other objects too or only TBB? Best Regards, Nikolay Zhelyazkov
I am happy to hear everything is fine. 🙂
- 25 replies
- a3
(and 2 more)
Tagged with:
If you get the same result when printing the pdf outside of VectorWorks, then probably the problem is in your printer.
- 25 replies
- a3
(and 2 more)
Tagged with:
Now I have noticed that the margins in the file you sent me are not the same as these in the picture from your comments, but are bigger on the left and right. Here is the result that I get when I export to pdf: test.pdf Did you try resetting your page size from Page Setup, but not from the print dialog, from File->Page Setup?
- 25 replies
- a3
(and 2 more)
Tagged with:
- Yes, but it includes the margins that you have set. You could edit the Title Block Border style and make it have wider right margin. This might compensate the issue for a workaround. However, I am not sure what could be causing your issue.
- 25 replies
- a3
(and 2 more)
Tagged with:
I am able to print correctly here, using A4 printer size. Before printing, try opening File->Page Setup and from there select your printer, printer size and make sure that the page is using One Printer Page size. If this does not fix your problem, you could first export to PDF and then try to print the pdf. Let me know about the result. 🙂
- 25 replies
- a3
(and 2 more)
Tagged with:
Yes, you could get a shareble link of the uploaded file from dropbox.
- 25 replies
- a3
(and 2 more)
Tagged with:
This is because it is using an object style. I suggest you read the help for the Title Block by clicking F1 while the preferences dialog is opened, so that you get to know with the object. It would be easier to help you if you could make a simple test file showing the issue and send it to me.
- 25 replies
- a3
(and 2 more)
Tagged with:
What version of VW are you using? If it is above VW 2018, then you are probably working with Title Block Border objects. If so, select the TBB, in the OIP from the Sheet Size popup select Fit To Printable area and your Title Block should automatically be fitting to your printable area and not be cut when printing.
- 25 replies
- a3
(and 2 more)
Tagged with:
- Could you upload it to dropbox or google drive? If this is the desired result, have you set your Title Block Border to be fitting to the printable area from Sheet Size?
- 25 replies
- a3
(and 2 more)
Tagged with:
Hello @KVW, Could you send me a test file and maybe a screenshot of the desired result of the print? Thanks, Nikolay Zhelyazkov
- 25 replies
- 1
- a3
(and 2 more)
Tagged with:
Edit Revision and issue data by worksheet
Nikolay Zhelyazkov replied to RussU's topic in General Discussion
Hello @sophiecanaris, The worksheet report Title Block Project Revision History should be doing exactly the same. Best Regards, Nikolay Zhelyazkov
