512 -
Posts posted by Gadzooks
Ok - (should have looked a little closer) Just seen you have multipane available in the dropdown - so you are on 2018
This sudden?
Could you confirm which VW you are using please.
(Would be helpful if you used a signature with this information in)
I like this! I'm upping it.
VW innovates with headliners, but there are some times when just looking at the basic tool sets can provide better workflow for users.
If there could be a subset of the oval tool that provides a 'half' mode that would be good also.
I've just tried this file on an iMac and it doesn't show the dreaded beach balls. (Probably not what you wanted to hear)
It seems the file is, as Kevin has confirmed (by having to take the whole thing to bits and redrawing!!), far too cumbersome due to the way you've had to import. Its not helped by wanting two of the same objects as well if you're going to split them - there might be mileage in the future to consider 1st, trying to reduce the faces as Kevin has done and then 2nd, opting for the use of symbols to help VW use (duplicate) the geometry at its most economic. Obviously symbols will only pay dividends the more there are.
1 hour ago, line-weight said:This is a problem I have with BIMobject; it's presented as all quick and easy but unfortunately nearly everything I download from there gives me the bloated messy nested/mesh objects that you describe.
I have the same problem with these files. If I'm designing a complex building I don't want (say) a single imported wc pan to increase the file size so much as they seem to. I've just had this on a project and when I examined the 'helpful' BIM Object it was easier to redraw parts and smooth other parts. It made the geometry much more useable. TBH I'm not sure of the 'value' getting into bed with BIM Object has brought to VW.
Perhaps @JimWor other could let us know how the future looks with BIM Object because, despite the fanfare, from my perspective the honeymoon is over and its not looking as rosy as the bride and groom had hoped? I'm obviously speaking as a disgruntled 'relative' that can't see it lasting I think the Brides father is fixing the brakes on the grooms car.
Maybe its time to seek therapy on that one!!
1 hour ago, Kevin McAllister said:The BIM objects or at least the BIM Object import process is what should be fixed in my opinion. VW should be smart enough to convert the volumes into generic solids or Subdivision objects. VW is a CAD program, not a polygon modeller.
Definitely - 100% . This is useful therapy. I recommend a course - but is not going to come cheap is it Kevin!
Some things I could offer that might help generally...
- Sometimes I've found it helpful (and often quicker than switching classes on and off etc) by quickly making the object you want to manipulate into a Group. Do what you want to it inside its 'own space' and then exit and ungroup.
- Also Ive found (and others may agree - or not!) that if you highlight the object first then use the PPT, VW seems to manage to disregard the geometry close by. On that one, all I can suggest is you might try it.
@Max Eand @mike m oz
Agree - Yes please. Placement and control thereafter is soooo clunky. Especially with roofs, but still affects walls.
The creation of roofs and walls is very similar and so I assume the control of 'inserts' is coded quite similarly. Both walls and roofs could do with code refreshing the way 'inserts' are placed and I use the phrase 'inserts' as I think that doors and windows (and any other objects that pass through ) should be able to share and be bound together in the same aperture as most designers want this flexibility. To be able to grab and move to another position is intuitive and is preferable in many situations. Obviously I'm not advocating that the tighter control offered by 'height in wall' or 'above slab' is lost - just supplemented by a degree of freedom to move quickly to "what if I move it here - what if it was a bit narrower there......" That's what design is all about - perhaps more so in the initial design stages.
- 1
21 minutes ago, Rob Books said:
we do have more manufacturers and product lines coming out
Good to know Rob.
Would it be a step too far to confirm if some of the long standing issues that remain with doors/windows (unless your in Oz) may be sorted in next SP's.
(Edit: Thanks for the above. - I misread what I thought was a shadow line on your earlier shot.)
Haha - well into it and, by the looks, enjoying your new toy. (You know that's going to leak don't you )
Just don't use the protractor!!..........We need you to be smiling still at the end of the day.
In case you've not seen that...
10 hours ago, Kevin McAllister said:I used the Rotate Tool at some point in the right hand pane....
(Can't wait for your VW 2018 DAY 3)
57 minutes ago, Ellen 7 said:
I have found that I can draw using the 3D polygon for most of my design
This will inevitably hold you back. It gets the job done for the moment if you're under pressure, but when you have more time you'll find learning an extended skill set will reap rewards in your productive time.
All the best for the learning curve. Don't be put off - with Vectorworks its not that steep before you are really happy with your creations. (Psst!, We're all learning still)
Kevin - Yes, sometimes it takes a counter-intuitive direction. I too would want it to stay on the selected plane.
Keeping your line in place, you can place the centre of your switches with snap set to 'distance' (fraction 1/3 chosen from options).
7 hours ago, Luis M Ruiz said:
Here is the result of my first test file as I was trying to study and understand the settings and future benefits.
As usual with your visuals - beautifully done Luis (never mind the quality - feel the width)
And, I'll take a suit in the Shantung, a waistcoat in the Cotton Twill and can you do me a onesie in the Purple Polyester (for special occasions obviously !)
@Ellen 7This might help initially...
BTW - It would be good if you added a signature with details about the VW version etc so any future help could be more focussed.
Good catch Kevin.
I hadn't seen this, but have now tried it and find it particularly annoying.
Annoying in that I can't dismiss the protractor and (frankly) annoying that the swift comment from VW Inc via @Chih-Pinis effectively "yes we know". (But not stated) "But didn't want the issue to cloud the (big fanfare) multi-pane release." Pity, as I've used multi-pane in other cad programs for years and expected it to arrive on VW2018 'sweet'.
I'd like to know if VW Inc would list all the other issues that they already know about (yes - like thats going to happen) and will be 'fixed' (caught up with) in the forthcoming SP releases. Would be nice though if there were at least some occasional posts from VW Inc in the 'Known Issues' section - It would be nice to show you're only human!
Meanwhile we users will stumble over the issues, day to day, thinking that we ought to help our fellow users by reporting to this forum.
Got that out of my system!
Moving on - In my limited testing, (and here's me back to trying to help) it seems the 'feature' relates only to the next pane used. And also the tool can't be reselected after this event/occurrence. Seems its 'locked-out'.
Just to add (so you can see I'm being fair!) - Generally VW2018 - from my use and reading of others use up to now - is stable and seems to lack any huge problems . And....yes folks, multi-pane is really good and will become second nature!
- 2
15 hours ago, digitalcarbon said:
Excellent modelling as always DC. Compulsive viewing is something I would never have thought of for a Vectorworks forum, but your posts definitely are!
On the screenshot - I see the smaller pipe entering the larger near its base (elevationally). In fact it is drawn slightly within the wall of the larger pipe and terminates on the centreline of the larger pipe. Yet the OpenGL pane looks slightly different - the smaller pipe appears slightly elevated and my eye says it should just about be seen within the larger pipe. Just an observation...anyone else 'see' this?
I'm assuming the boffins didn't want to automate how new menu items are transitioned to custom workspace menus, as the placement is entirely up to the 'owner' and they should oversee that manually.
33 minutes ago, zoomer said:
Not sure if it would have worked by pulling the parent entry from "What changed"/2018,
as I did it manually already.
Like this?
Thats what I couldn't seem to work out. I expected the full menu and sub headings.
No great harm done - got there in the end.
I've just been able to add this by manually adding a 'New Menu' followed by the submenus
Edit: (Which behaves as expected btw)
I assume thats down to me then - although I would have preferred it to be seamless
Zoomer - It started so well......
I've just taken the wrapper off 2018 and started to see if I can be (foolish enough?) committing live projects to it.
2 hours ago, zoomer said:As far as I can see only the new Menu Entry for "Multiple View Panes" was missing.
I usually use a custom workspace and this is missing for me also.
Have you tried adding it through the editor? I can't get it to modify the custom workspace complete with its sub menus. It insists on listing the submenus.
This is what I have..
Whereas it should of course be..
Something I'm doing wrong?
Thanks - rookie mistake then. Or more likely I'll convince myself I was in too much of a rush.
I believe (of my earlier options) it's the new glasses then.
Thanks again.
18 hours ago, GVRT said:
I have no idea why rotating around the insertion point when label legends are applied isn't default in VW anyway!
Guys - I can't even get this to work in a simple manner.
On reading this thread, I thought I would have a look for any answers to help @GVRTand came across the the following glitch (or feature?).
To establish an insertion point for a simple symbol looks easy....
(Just to make clear - they were dashed lines before I did a screen capture
Edit - I've just seen that should of course say leftmost part of the symbol (doh!!)
Either this is..
- My ineptitude - And someone will point this out to me. (gently does it!)
- Vectorworks problem - And this is a known issue..
- Vectorworks new issue (can't believe this really, as someone else will have raised it and I haven't seen anything on this forum)
- I need new glasses.
Sorry to jump on this thread BTW, but it seemed appropriate.
18 hours ago, zoomer said:
Enthusiasm little cooled down after hours of playing
Ahhhhhh..........a little like a Vectorworks upgrade?
- 2
Sometimes it's about using work-arounds rather than slogging away with the standard tools.
Assuming you want to have the wall projection in a different texture/colour just for the render/visual, whilst still maintaining your basic 2D layout ....
- Would applying a decal to the wall in the correct position/texture provide the solution?
- Would using the extract tool provide the shape for its own texture just a 'nudge' (to keep geometry apart) in front of your added wall feature?
There is a good 'how-to' of the technique with different finishes on walls here....
The first to congratulate you! Well done and many more.
I thought it would be like the speedo on my car - I'd look down expecting 10000 and Id've missed it and it would be showing 10001
Im waiting for the next milestone obviously. Too many noughts! Just had to edit it in my excitement.
Yes, it's all in the brief really. We're not sure what @KyleBlasius has in mind.
Where did my, back and rear views go?
in General Discussion
Posted
Haha - Just getting there myself
