33 -
Reputation
18 GoodPersonal Information
Location
Norway
Recent Profile Visitors
3,357 profile views
Export to Unreal Datasmith - light object naming
Endre Torkildsen posted a question in Troubleshooting
I have seen a post on this earlier, but cant seem to find it, therefore: When exporting to Unreal Datasmit, it seems that symbols that contain lights or "single" lights do not have any name. If I import a .udatasmith file in Twinmotion, the lights show up as " Spot_light_1" -> "Spot_light_xx". I can't see any patterns where the number reflects when the object was created, or if the file sort the light from top to bottom. haven't seen any logical pattern. Is there anyone that have any information about this? If there is a field in VWX that can be named, and transferred to the export, it would like to know 🙂 -
Endre Torkildsen changed their profile photo
Did you save the file, close and re-open? I often have had the same happend to me when import large dwg`s, without save..
Had the same issue, was looking for a VMB tower some time last year. Ended up having the drawings from our supplier and modelled it my self, and added some Marionette magic as well. Screen Recording 2021-12-31 at 21.32.47.mov
Page size is not correct according to settings?
Endre Torkildsen replied to Endre Torkildsen's question in Troubleshooting
Thank you!! -
I can sendt a copy of the file on a private message! 🙂 -
I have a strange problem I havent had before. When i set my settings to page size A3, the page will not update to the correct size.. When my settings shows A3 420 x 297mm, the page is actually 525 x 371mm.. Someone have some tips? I havent started this file, and i have not tried to copy all to a black file.. Just seems a bit to much work, just to have the sheet-pdf to be correct.. -
Disappearing geometry bug inside Symbol Edit / Inside Extrude Edit
Endre Torkildsen replied to Elite Exhibits's question in Troubleshooting
Im running VW2022 SP3.1 on a Mac M1 Max running OS 12.0.1. -
I have had kinda the same issue. 3D geometry that not will show up in "shaded" view.. Geometry missing in shaded view..mov -
Hi, See the attached file. I guess this is the one you looking for? Remember that these clamps is designed to be used in pair of two.. Doughty gravlock coupler.vwx
- 1 reply
- 5
Hi, Is it possible to assign a shortcut to the "rotated top / plan" option in the view menu? This option only appears if you rotate the plan view. I know there are a few workarounds if you use saved views etc, but this would not solve this for me. My use for this would be if I'm working in different views rotated, and switching back and forth between top view and front view.. Screenshot attached is showing the menu option I would like a shortcut for.
@Antonio Landsberger Thank you for the answer! If the scale is a thing I will keep that in mind and try to stay on the same. Will this also be a "bug" if you drop a red symbol onto a design layer(same scale as created) and then later on change scale?
Hi, Im not sure if I am the only one that have this problem but the following is happening. I have a lot of marionette plugin symbols drawn in different files. If I try to copy a plugin-symbol from the file that I build the plugin in, to a new file the symbol disappears as soon as i try to do some changes to the the symbol. This also happens if I rotate the symbol from top/plan 2D. It seems that some of the nodes looses its connections when i do the copy/paste operation.. I have made a screenshot trying to show the problem.. Its kinda confusing because i have spent a-lot of time on some of these plugin-symbols.. My version is 2021 SP3.1 (build588748), running from a Macbook pro M1. Marionette copy:paste bug.mov
spries started following Endre Torkildsen
Came up a question in the Vectorworks Spotlight user group at facebook: Anyone know how to change the position of the leveler on a screw jack? Made a quite simple plugin symbol for this. Layher base 20 w:handle adjustable.mov Layher adjustable base 20.vwx
Hi, I have made a few more truss parts that Milos have in their "standard" stock, also some pickup symbols that I use a-lot. Who will be the right person to talk to, to have this added to the service-select library? (I guess that there is not only me that wants this symbols). Attached are some screenshots of the parts.
