193 -
@gloudon Apparently, @Berntsen was able to open the project file -- finally. It just took hours! The report we got back from Vectorworks support was: Looks like there are some guest resources leftover from references that are gone. These have a lot of resources to delete, and they are expensive to process. Saving and recreating the project is one way to get those cleaned out and back to normal.
Really looking forward to getting Thumbnails/Previews back!
We have a Landmark user here in Norway who wants a way for get a grade object to snap to another site modifier in z-value. This could be very useful when designing and you need to adjust heights of site modifiers based on other site modifiers you have already drawn. Retrieving height from the model itself does not work here as the grade object with the wrong height helps define the model and thus also gives the wrong height. Grade objects should be able to snap to site modifiers in open edge line mode in the same way they are able to snap to other grades…
- 1 reply
- 4
Daniel Ewald started following Scott Campbell
Mirror Site Modifiers
Scott Campbell replied to Malene's question in Wishlist - Feature and Content Requests
It appears, as you point out, Malene, that mirroring site modifiers is not supported -- as of yet -- in Vectorworks. Thanks for taking the time to list this wish. You can tag other users you know and ask them to "vote up" your wish, like @Knut Andreas and @Daniel Ewald and @aage.langedrag -
Length of railing and fence as a property in IFC?
Scott Campbell replied to aage.langedrag's topic in General Discussion
@aage.langedrag I will pass along your comments about finding parameters and expectations for info in the OIP. You make good points. As for the rounding/reporting of the value, I’ll check further and see if I can find an explanation or a workaround. As you imply, I may have to buglist this too. -
Hi Åge -- It seems if one selects "Length(3d)" under "Specialized for Fence" in the Select Function dialog, we get a correct calculation. What I don't understand is why the value returned is 0.003. The Fence in your file is 2.685 meters long. The returned value seems to be that value rounded and divided by 1000. 0.003 is the Length value for the Railing too, which you say shows correctly. Can you shed some light? -
Hi Stefan -- This sure sounds like something you ought to be able to achieve by scripting. Good opportunity for diving into Vectorscript, perhaps? Sorry to say, this is far from my strong suit, but there's a useful introduction to scripting in Vectorworks (both Vectorscript and Python) here: https://university.vectorworks.net/mod/scorm/player.php?a=348¤torg=articulate_rise&scoid=696
Site model contours - update 4
Scott Campbell replied to Ross Harris's question in Wishlist - Feature and Content Requests
In the Site Model Settings, deactivate "Custom lable placement" and put in 0 for "Maximum Labels per contour." OK. This will eliminate all automatically generated contour labels. Then go back and activate "Custom label placement." You'll now be able to use the "Add Contour Labels" button on the OI-palette to create your labels along a polyline wherever you want them. -
Thanks for the clarification. As far as I know, the "Truss Properties" dialog can only be accessed via an instance in model (right-click on truss instance and chose from context menu). So, that brings us back to start: Vectorworks crashes when attempting to place an instance of a Truss object in the model. I think we need to troubleshoot based on the crash, and now it seems necessary to ask you to share a file with the Truss culprit, if you can, for testing. Thanks.
Right click on the Truss symbol in the Resource Manager and select "Attach Record…". Highlight the Record you wish to edit, then click the "Edit values…" button. Be aware that the edited record values will not be updated in any truss instances previously created in the model.
