Content Count
92 -
Community Reputation
6 NeutralAbout Robert Janiak
Rank
Apprentice
Personal Information
Homepage
www.stagevision.pl
Location
Poland
Recent Profile Visitors
1,434 profile views
@bbudzon Thanks, but I need emissive a lot of custom triangle led tubes fixture.
Hi All, How can I add RGB Emissive for a large quantities of elements? Is avaliable any automation or trick?
I am looking for a solution to encrypt many plugins simultaneously using external IDE for developing.
Hi Everybody, I am trying using vs.EncryptPlugin() for encryption menu command with imported external _main.py file in it but VW 2019 says 'setting file can not be read:' What does this errors means? Encryption works in Plugin Menu if I add xml file but vs.EncryptPlugin() still has error. What does vs.EncryptPlugin() and vs.EncryptAllPlugin() do? I have BatchEncryption.vlb from SDK
Hi, I can not record video using DMX Camera. I have got still shoot from one side. DMX camera is being record and play by DMX recorder properly and works well in preview window. If I try render video by build command I get only one camera, no movement and no camera changing. Can Vision 2019 rendering DMX Camera? This is a demo recorded by OBS Studio from Live view. I would like to do this directly in Vision without editing. Otherwise, recording screen cause low FPS and quality is poor. https://drive.google.com/file/d/1mu0Q5QclavpwYE4lYGQDVA3Ju-xSXjJs Next case, camera movement and rotation speed controlled by DMX has high sensitivity. In my opinion speed should be divided by 10 or even 100 for natural control. This is my first time with dmx camera and video. Does anyone has any advice for this?
Martijn Wingelaar started following Robert Janiak
@JuanP @JuanP hi, can i get link for Vision? I have VSS but I have no link to Vision in Poland.
Ok. I did not report it.
How can I turn off Movement Radius class if Modify Lighting Instrument color is enabled and set to Lighting instrument?
I find solution, Disabling Auto Positioning when moved fixed this.
@markdd 🙂 I forgot about Move by ponts. Thanks a lot
Hi, Red diamond and line show up if lighting device in moving to new location. Can not leave device on truss edge. Lighting device automaticaly move to center of truss. Why? Truss is converted to Hunging Position. SP4 490894
@lwhit Hi, For me sACN works wit h ethernet switch or Wi-Fi router conected for loop. Artnet works betwen two machines only. Why? I do not idea.
It was accidentally problem. I can not reply again. I think, ethernet configuration was wrong.
I have problem with sACN. Some universes do not works. Problem is strange. The same universe changed to ArtNet does works.
@CETLV Thanks, it looks like a very simple method. I will check this.
