Martijn Wingelaar
    70
Reputation
12 Good
4 Followers
Personal Information
  • Occupation
    rigger
  • Homepage
    www.vectorbridle.com
  • Location
    the netherlands
Recent Profile Visitors
  1. Hello ratherfishing. You can use Convert Truss to Symbol. But this does it for all trusses of the selected truss in the drawing. Greetings Martijn.
  2. VE-107598 VE-104957 VE-104430 VE-106098
  3. @Nikolay Zhelyazkov Hi Nikolay. I pointed this oud in a Jira post aswell on 13-06-25 It should behave more like in my attached movies 😃👍 Bridle 1.mov Bridle 2.mov
  4. Hello Mike. I just made a marionette node for it. Schermopname 2025-12-23 om 20.45.03.mov
  5. Got it. turns out if you use the original Plugin name it works with Domenu.
  6. Hello everyone. Is there a way to let Marionette open a Shortcut? I try to make a Marionette Command. To open the Braceworks Add pointload to selection command. But can't figure out to let it open a Shortcut. Is that possible? Greetings Martijn.
  7. Michael Schroeder. Are you kidding me. i use Loads a lot if I get a plot with weights in it. And this is a super idea from you. Greeting Martijn.
  8. Hey Jesse you rock 🤘. That works indeed. Now I can make another few hundred custom tools 😆. Greetings Martijn
  9. Hello everyone. Does anyone knows a way to select only the deadhang bridles in a drawing? I can't figure out how to do it. If I select a Deadhang and try to do a select simular option. It also selects all 2 and 3 Leg bridles. Greetings Martijn.
  10. That's exactly not what I want to do. I just want a quick count. 😬 Greetings Martijn.
  11. Hello i've got a question. Does anyone know how to get a worksheet with the virtual parts? I can't find it in the worksheet options. Greetings Martijn
  12. Hello all. I think it's not possible what I want but. Is there a. way to get the Bridle Configuration steel info for a Deadhang Bridle? I got it for a 2 and 3 leg Bridle. But a Deadhang uses different information I think. The Tag Definition in the added picture does not work. Anyone ????? Greetings Martijn.
  13. Hello ldenambride. If you are going to make your own pickups. Maybe it's a good thing to keep in mind is that all the by Vectorworks provided slinging methods are actually wrong. And disapproved by most truss manufacturers. I have made my own it's not so difficult to do. Greetings Martijn
  14. Hello Matteo17. Yes you have. Under Hoist Tools - Hoist Standard-Euro - C1. But you have to check if all the data is correct. By most of the hoist the body weight and chain weight are incorrect. Greetings Martijn
  15. Hello forum users. I am trying to create a Data tag from a selection of trusses. Is there a way to do this? I can't figure out how to do this. I try to get all the length of the used trusses in a selection. Greetings Martijn.
