P Retondo
Content Count
1,806 -
Calendar
Everything posted by P Retondo
RepRap support
P Retondo replied to Christiaan's question in Wishlist - Feature and Content Requests
Christiaan, this is just another of the many 3d modeling technologies that have been out there for more than 10 years. File formats such as .sla have been developed to communicate with equipment of this type, and it is currently possible to get a VW 3d model to be fabricated on such equipment - but it would take major tweaking because of interface difficulties. I've never gotten beyond the initial discussion phase in such an effort because the cost is just too high. But, someday . . . Bear in mind with the "RepRap" idea that "it would still require an external supply of several currently non-replicable components such as sensors, stepper motors, cameras, or microcontrollers," per the apparently self-authored Wikipedia article. Not too many people are going to want to build one of these in their home workshop. -
I was having trouble with my DTM texture beds displaying as a wireframe object only. Problem solved by Gunther at NNA! There are two fields in the OIP where the texture bed class has to be entered - the normal field with a drop-down menu at the top, and a second field more towards the middle of the dialog box, where you have to type in the class name. Once you do this the texture bed rendering will be displayed. I've asked Gunther if the code can be changed so that it would be unnecessary to enter the class two times.
I believe this has been submitted to the wish list in the path. ACAD has the capability to scale blocks, and many people naturally wish that VW symbols could be scaled. It would take advantage of the symbol object in a more powerful way.
Sorry to say that I think implementing "referenced classes" would be a mistake. It complicates the program works in a way that would create instability. Look at all the problems we already have with just saving files on a server. A better system, which might save the same purspose if we have the ability to import classes, is a VS utility that each user could run, or would automatically run upon booting the program, that would import any new classes from your office standard. That way, any office that desires to have this kind of system could use the utility without creating messy file interchange protocols within the VW core.
I'm not saying we shouldn't support the metric system and European standards - though I am in the dark, probably through pure ignorance, about what aspects of these are not currently supported. I am merely pointing out that if one wishes to apportion the economic support of users to the software's base capabilities, one should look not at the last year or two but the whole history. I'm seeing metric units supported, and metric fasteners - is there a list of other things that need metric defaults/choices?
The vast majority of current users are beneficiaries of years of work on the program, supported in the early years almost exclusively by the US market - both in terms of economic support as buyers, and in terms of countless hours of user feedback and work process development that have been incorporated as a added value to the program. Based quite naturally on the momentum of these early years, NNA may still lean a bit towards the requirements of the North American market. Some choose to complain about the current situation without acknowledging the whole history. That said, it could only be good for all of us if NNA pays heed to the needs of the worldwide market and all it's local nuances.
Jason, Dimensions in the Design Layer will show up in a Viewport if their class is turned on.
To set the default height for walls you create, set the layer Z+/- to some value other than 0.
Horizontal board textures should align
P Retondo replied to P Retondo's question in Wishlist - Feature and Content Requests
Good suggestion! -
I need to really speed up 3d hidden line. HELP
P Retondo replied to mcobbs's topic in General Discussion
Unfortunately the only thing I think you can do as a user is to purchase a faster processor. It would help enormously if NNA were to make all the rendering processes work to utilize multiple processors more fully. -
Katie, you just made checking this board worth it for the last week. I was going to say that the lack of this capability was the one thing ACAD had over VW, but not so! And Ray, your tip about using "View outside group" is another great one. I note that this doesn't work for Section Viewports. I'm also curious - when I translate a plan view in a viewport, the section line indicators stay in place as part of the annotations. Does that mean that the corresponding section viewports are going to change? BTW, if I am looking for something in a Design Layer, rather than change the Viewport scale, I just remove the crop or make it larger. Having the crop shape be independent of the Viewport object is a key structural adavantage over ACAD viewports.
P Retondo posted a question in Wishlist - Feature and Content Requests
When horizontal board textures are applied to walls, they often don't line up from wall to wall because they are applied with reference to the object instead of "world" coordinates. This could be corrected if, similar to how pattern fills are aligned from object to object, the default alignment of wall textures is to the ground plane instead of to some point on the object. -
No one in the world (I trust Petri to correct me if I'm wrong about this!), except perhaps those who engineered the VW joist framing tool, miters rim joists. It's a pain to have to undo all those 45 degree ends and stretch them to look like the architect had some idea of how buildings are built.
Option to have WGR's unlocked
The way things work now, all objects on WGR layers are locked. If one unlocks them, they automatically get locked again when the WRG is updated. One unfortunate side effect is that Section Viewports don't pick up those objects as part of the section, they are treated as background objects. I think this may be a bug, but it would work fine if we could choose whether a WGR layer is default locked or not locked. -
. . . a "None" fill and a zero lineweight. By panning and zooming, if you're an AutoCAD user, you probably mean scaling and moving the viewport boundary. In VW, panning and zooming the screen view does not change the scale or boundary of the viewport, you have to do those things by changing the scale of the VP in the OIP, and by actually moving the VP crop boundary. Once you get used to the way it works, it's as good or better than the ACAD system.
Import Vectorworks document
To import all objects from a layer, including the layer name (which should be different from your existing layer names), add a Workgroup Refrence. Delete the reference and save the objects. C'est fini! What Christiaan is talking about is a more sophisticated and controllable import feature, and I would like it to include the ability to import Sheet Layers and Viewports. (BTW, Christiaan, is that pronounced "yeep" or "yep?") -
I'm stumped - how do I paste in an image? When I click on the image icon, I get the same URL prompt we always used to get.
Nicholas, thanks, I'll submit a bug report.
I can't get a texture bed to display a texture. It always displays as a wireframe only: Has anyone had success using the texture bed site modifier?
This would be welcome. For example, the eyedropper tool is set by default not to pick up PIO attributes, and everytime I open VW I have to change this parameter.
I use the tool Mike recommends with a keyboard shortcut. It's in constant use.
Viewports have the ability to scale lineweights. Check the advanced properties and see if the lineweight scale is a value <1. That alone doesn't explain the difference between viewport and design layer, as the attached images demonstrate. The first is from a design layer, the second the same objects in a Viewport with line scale set to 1. The Viewport lines are thinner. I believe this could be a bug, and will submit it.
bc, I agree completely that the previous view history should be controllable and that it should extend back at least 20 or more views. If it is based on the "Saved View" algorithm, why not have a drop down list of 1-20 so that we can just go to the view we think is relevant? The ultimate - a scrollable list with thumbnails of the last 20 or so views.
I can verify this. I think it's a bug.
