Mr.Toast Posted June 22, 2022 Share Posted June 22, 2022 I like to use a particular font for my work but since importing it, it has this weird extra spacing between each word I can't get rid of. I've used a font editor and a lot of the edit show except the changes to the spacebars input in VW. But get this, in Word it works just fine! it shows the spacing changes I (while extreme in the example shown) but no avail in VW 😞 SEE EXAMPLE PHOTOS I'm sure you can tell which ones in Word and which ones in VW Quote Link to comment
Administrator JuanP Posted June 22, 2022 Administrator Share Posted June 22, 2022 @Mr.Toast Have you tried toggling the "Wrap text" option in the OIP? Also, it will help if you can add the OS, Vectorworks version and SP, and Computer specs - thanks. Quote Link to comment
LarryO Posted June 22, 2022 Share Posted June 22, 2022 I looks like you have 'Wrap Text' selected (fixed width) and 'Horiz Align' set to Justify. Quote Link to comment
Mr.Toast Posted July 13, 2022 Author Share Posted July 13, 2022 On 6/22/2022 at 7:59 AM, JuanP said: @Mr.Toast Have you tried toggling the "Wrap text" option in the OIP? Also, it will help if you can add the OS, Vectorworks version and SP, and Computer specs - thanks. @JuanP @LarryO Wrap text does not change the spacing, and it is not justified by the horizontal alignment setting. Very peculiar problem I'm using VW 2021 SP1 Build 568598 64 bit on Windows 11 Ryzen 5600x cpu 32gb ram RTX 3070 gpu Thanks for your replies and effort in this Quote Link to comment
zoomer Posted July 13, 2022 Share Posted July 13, 2022 (edited) But VW 2021 should already be SP 5 or 6. Edit : Should be SP5. At least that is what I have .... It is important to update VW to the latest current SP. Even more with older VW Versions on newest operating systems. If VW does not show SP updates automatically close VW and open the VW Updater App directly from within the VW App Folder by Apple Finder/Windows Explorer. Edited July 13, 2022 by zoomer Quote Link to comment
