Benjamin Posted June 3, 2000 Share Posted June 3, 2000 I've tried for many hour the save an image to disk in the various formats of vector works...Is there a particular process I need to follow Quote Link to comment
MikeB Posted June 5, 2000 Share Posted June 5, 2000 You use the export image file command in the file menu. Also you need to have the latest version of Quick Time, you can get the Mac and PC versions from the apple web site. the general process is to set up your view, Render it on screen then go to the export image file command and follow the dialogue. A second way is to use the render bit map tool. Although if your image is large or complex you will have to render it in pieces and past it into Photoshop (or equal) to put it back together. Good Luck Quote Link to comment
Bruce Kieffer Posted August 26, 2000 Share Posted August 26, 2000 If your having trouble achieving a resolution higher than 72 DPI using the "export image" command on a Mac, well that's because it's still a broken function. It was claimed to be fixed, but I guess no one really tested it. When I called to ask why I still couldn't get it to work, they were a bit surprised, but they did confirm it's still broken. Quote Link to comment
Danielj1 Posted August 26, 2000 Share Posted August 26, 2000 Well, I just tried it on my Mac. Used Renderworks for the image, exported it as a 300dpi JPEG. Opened it in Photoshop, which reported it as a 300 pixel-per-inch image. OS9.04, VW8.5.2. Dan Jansenson Quote Link to comment
Bruce Kieffer Posted August 27, 2000 Share Posted August 27, 2000 Daniel, Thanks... I just tested it again on my Mac, and it works! I know the last time I tried, both VectorWorks Tech Support and I could not get it to work. I must have updated some part of my system so it now works. I found that exporting as a Photoshop file is a cleaner image than a JPEG. Quote Link to comment
MikeB Posted August 29, 2000 Share Posted August 29, 2000 Keep in mind if you increase your resolution to 300 dpi you are not getting a higher resolution image, you are getting the same number of pixels in a smaller physical area when printed. The two numbers at the top left of the export dialogue box are the size of the exported image in pixels. If you dont increase the number of pixels you aren't getting any more information by increasing the dpi, you are expressing the same information in less physical space when printed. say you have an image that is 1000 x 1000 pixels. at 100 dpi it is 10" x 10", at 200 dpi it is 5" x 5". I've also found that increaseing the pixel size in the export dialogue dosen't work(usually causes a crash on mac and pc), you have to increase the size of your perspective marque so the image in physically larger in the file. I hope this makes sense, It's not explained anywhere in the VW or RW documentation, but it is critical to understand if you want really high resolution images. Good Luck Quote Link to comment
MikeB Posted August 29, 2000 Share Posted August 29, 2000 Ill try to increase the pixel dimension again, its been awhile since I tried it last. Does anyone know if there is a max # of pixels you can export, I posted this earlier but got no response, it seems to be around 6 million. I know if I get the pixel dimension too high when I hit "OK" in the export dialogue, the screen kind of blinks and the image is exported instsantly as all black(no picture). Just thought I'd ask again Quote Link to comment
Danielj1 Posted August 30, 2000 Share Posted August 30, 2000 The procedure is described in detail and specificity in Janis Kent's book, the WorksManual 8.5. I've exported many many images, at multiple resolutions with no crashes at all. Just to make sure, I just tried it again, doubling the number of pixels in the dialog box, increasing the resolution from 72dpi to 600, and adjusting the export resolution in the Raster Render preferences box to 600dpi. The image (in JPEG format) exported perfectly, with no crash. Make sure you have enough RAM and the latest version of Quicktime; I believe one or two versions ago there were documented export problems. Dan J. Quote Link to comment
Tim Rodier Posted October 4, 2000 Share Posted October 4, 2000 I can't answer your max pixel question, but what your describing sounds familiar. If when I export an image I click on the preview button (PC v. 8.5) for file size ect., the resulting image that is saved is blank; a white screen. As long as I don't hit the preview button, I'm fine. Quote Link to comment
