Hans Boman Posted April 7, 2022 Share Posted April 7, 2022 Hello! Most of my projects are quite small, for instance new villas or extensions of them. I have problems rendering the facades with the create section viewport command. The different stories, often no more than two, do not connect correctly and the result is ugly horizontal lines where the stories connect on all the facades. This only show when rendered in hidden line, in shaded mode it's ok, no horizontal lines. The lines give me a lot of extra work to cover up. It probably is only a simple setting somewhere, but I have not found it. Can someone help? Hans Boman, Sweden Quote Link to comment
Tom W. Posted April 7, 2022 Share Posted April 7, 2022 In a section VP you should enable 'Merge Structural Objects with Same Fill' to remove the lines between walls stacked on top of each other: Quote Link to comment
Hans Boman Posted April 8, 2022 Author Share Posted April 8, 2022 Sorry, that did not help... Quote Link to comment
shorter Posted April 8, 2022 Share Posted April 8, 2022 On 4/7/2022 at 11:25 AM, Hans Boman said: Hello! Most of my projects are quite small, for instance new villas or extensions of them. I have problems rendering the facades with the create section viewport command. The different stories, often no more than two, do not connect correctly and the result is ugly horizontal lines where the stories connect on all the facades. This only show when rendered in hidden line, in shaded mode it's ok, no horizontal lines. The lines give me a lot of extra work to cover up. It probably is only a simple setting somewhere, but I have not found it. Can someone help? Hans Boman, Sweden An example image would help understand the issue. most problems we encounter are due to how things are modelled. Quote Link to comment
Hans Boman Posted April 13, 2022 Author Share Posted April 13, 2022 I will be back after easter holidays. Busy... Quote Link to comment
Guest Wes Gardner Posted April 14, 2022 Share Posted April 14, 2022 @Hans Boman it sounds as if it's a modeling error Either the top of the wall on the first floor is short of the bottom of the wall on the second OR Walls aren't aligned in plan view...if you post a simplified version of your file, I'm sure we can get that worked out for you... Wes Quote Link to comment
