Hans Boman
13 -
Reputation
2 NeutralPersonal Information
Occupation
Architect
Homepage
www.hansboman.se
Location
Sweden
Recent Profile Visitors
Thank you all for your suggestions! I will get to it in the end of this week and if I have further questions I will return to this topic. Once again, thank you!
When using the window or door tool you get a simplyfied rendition of a window or a door when you insert it in your drawing/model. I work in Sweden and sometimes I would like to insert a door or window that looks more similar to the product in real life. The cross section of the jamb, sash, shin etc is a bit more complicated in Sweden than the ones you get in the window styles library. In fact the only style that has cross sections that reminds me of real Swedish windows are the Velfac UK windows. The simplyfied windows are most times ok, but I would like to have a window style that I can use to ceate a swedish window. Windows made before ca 1970 often had two (2) parallell sets of sashes... Thanks for feedback and/or tips on how to create a new window style with other cross sections of jamb and sash etc than provided in the style library.
I will be back after easter holidays. Busy...
Sorry, that did not help...
Hello! Most of my projects are quite small, for instance new villas or extensions of them. I have problems rendering the facades with the create section viewport command. The different stories, often no more than two, do not connect correctly and the result is ugly horizontal lines where the stories connect on all the facades. This only show when rendered in hidden line, in shaded mode it's ok, no horizontal lines. The lines give me a lot of extra work to cover up. It probably is only a simple setting somewhere, but I have not found it. Can someone help? Hans Boman, Sweden
ID-tags for doors and windows
Hans Boman replied to Hans Boman's question in Wishlist - Feature and Content Requests
Thank you, you have been of great help! -
No, not so!
Oh, my doors and windows are symbols, but thanks to you I found that out. Font and size are now as I like. Halfway, then. If I would like to turn all tags off in one move - is that possible? -
I think I was unclear... When I created the doors and windows with the tool I checked the "show tag in 2D"-box in the settings. But the tags come in different size and font... I would like to edit that. In the resource manager I have "data tag styles", but editing that doesn't affect my tags. And I would rather be able to turn them off. -
No, I am sorry...
Hello! How do I delete unwanted objects that are only shown in my viewports? I have made a medel of a office/storage-building in two stories. When creating viewports, in one of the outer walls I get an unidentified object that only shows i the viewports - all of them and nowhere else. It is protruding out of the wall like a bizarre sculpture, remiding of a deformed wall. I have gone through all my layers and classes with microscope, but there is nothing there! At least nothing that shows... If I delete the wall it is protruding from, it remains i thin air in seen the viewports. Any ideas, anyone? Hans Boman, Landskrona Sweden
Hans Boman posted a question in Wishlist - Feature and Content Requests
Hello! I am a relativly new user of VW and I have two questions regading ID tags and their attrubutes. 1. I can not find clear and easy instructions on how to get control over the tags. I would like to have control over text size and font. At this moment my tags initialized in the door and window tools creates tags with different size and font. How and where do I control the attributes of my tags? 2. How do I turn the tags on and off? I would like to create two sets of sheets with horizontal section viewports - one with the ID-tags showing and one without. Can I place the tags in a separate class that I with one click turn the visibility off? Regards, Hans Boman, Landskrona Sweden
