Importing skp files into VW Landmark
Todd
Hi,
I'm drawing a landscape model and section and would like to populate with people figures. Importing them (3D figures) from SketchUp doesn't seem to work.
Any suggestions, using Skp or other, greatly appreciated.
Thanks!
Edited by Todd
Are you getting an error message? Or what specifically isn't working?
One thing to check is that the SketchUp file version is at least one or two versions older than the Vectorworks version you're using. Currently VW2022 can only import SKP 2020 or older (I'm not sure why it can't import 2021 - in years past I thought it was always one version older)...
If you're downloading models from the 3D Warehouse, I recommend just downloading the oldest filetype available.
Check your class visibility for the Viewport. The SketchUp import would've brought in any classes (aka Layers/Tags in SketchUp) from the original file, and those Classes are probably off by default in your existing Viewports.
In particular a class called "Layer0" is commonly found in SketchUp imports.
Edited by Andy Broomell
