Eamonn Posted January 29, 2022 Share Posted January 29, 2022 Is there any way to assign two+ keyboard shot-cuts to one program function? e.g... "Control & G" and or "Control &..." Quote Link to comment
markdd Posted January 29, 2022 Share Posted January 29, 2022 No. But you could add a command to a Context menu so it appears in the drop-down menu when you right-click. To do that you will need to use the Workspace editor which is relatively straightforward. Quote Link to comment
Eamonn Posted January 29, 2022 Author Share Posted January 29, 2022 17 hours ago, markdd said: No. But you could add a command to a Context menu so it appears in the drop-down menu when you right-click. To do that you will need to use the Workspace editor which is relatively straightforward. Interesting, I'll have a wee look a "Editor" then, thanks. Colombo impression... "One last thing." Is there a way to assign the top row of numbers (1-9) on a keyboard to an external keypad or even to a keyboard keypad? Their functions are different, eg... If I press 2 on the upper row I get "Line" and if I press 2 on external keypad I get a view. Quote Link to comment
E|FA Posted January 30, 2022 Share Posted January 30, 2022 My understanding is that VW treats the top row number keys differently than the number pad, and that the number pad keys can not be modified. See the last page of this PDF: https://app-help.vectorworks.net/2022/eng/assets/docs/VWKeyboardShortcuts.pdf Quote Link to comment
