Eamonn
37 -
Reputation
1 NeutralPersonal Information
Location
Afghanistan
Recent Profile Visitors
"... then use the "Rotate 3D View" command..." Thanks I will give this a try tomorrow.
Hello, I have my keypad views. Front, sides, back, top, 45 degree looking down... but is there a way of view from 45 degrees but level, just like a front/side/back view? Thanks.
Interesting, I'll have a wee look a "Editor" then, thanks. Colombo impression... "One last thing." Is there a way to assign the top row of numbers (1-9) on a keyboard to an external keypad or even to a keyboard keypad? Their functions are different, eg... If I press 2 on the upper row I get "Line" and if I press 2 on external keypad I get a view.
Is there any way to assign two+ keyboard shot-cuts to one program function? e.g... "Control & G" and or "Control &..."
Thanks... noob here. I wonder if there's a way to change the font size on the text within the "Navigation-Classes", (The Classes Labels)? Or even a way to edit it? e.g. Inserting line breaks? etc... I know you can set up sub-classes. I'm talking more a visual eye thing. Much the way you can add colors and lines to Excel.
Could you please post a screen shot to where I find class filters?
I think I will start with this idea first and try it for a while, then try some others. One question though... How do you name/label Classes so that they would always appear at the top of the two drop down windows, ie... The "Navigation-Classes" window and the "Object Info-Shape" window? I want this so I can avoid always having to scroll down to find them in different places each time. Some of the drawings I work on have a list of classes as long as your arm so having them always appearing at the top is preferable. I'm thinking labeling them with the number 0 at the beginning?
I've tried to attach an image but got "(Error code: -200)" warning. Is there a way for me to attach the image.
Great, thanks again. I will set up a template file.👍
Thanks, that's great. Is there a way to save my new Dim Standard to all furture drawings? I only ask because I opened a new document and my new "Dim Std" was not available. I would like for it to be always available going forward.
Hello, when I dimension something the actual numbers appear above the line. For tidiness/presentation I drag each box down on to the line. Is there a way to preset this up so that the box/numbers are always on the box? Also are there ways to preset dimension preferences. eg... The leader lines are removed, decimal places, etc... Thanks.
Hello, when I draw a rectangle and it turns white, to show it's enclosed. For me it's a different colour. I change it back in attuites but it doesn't stay like the the next day, or in a new drawing. Does anyone know what I've pressed or selected? Thanks.
Thanks guys, I'm in over my head but will slowly go through all that was mentioned here over the coming months.
Maybe what I mean is... can I make new classes that are there within the Vectorworks classes menu list always... if you know what I mean?
Hi, When I make a new class, is there a way to save it so that when I reopen the drawing, at a later date, that class is there for me? At the moment it's not there after opening it again.
