Jake124 Posted January 26, 2022 Share Posted January 26, 2022 I would like to change the font colour of one of the fields of a label legend if the light it is attached to has a particular value in one of the user fields. I can see in the manual that Data visualisations do not apply to label legends. I have already changed the pen colour of the light itself to the colour, but I woud like to also change the User field 1 (present in the label legend) text colour to the same colour. Within one drawing I am expecting to have a number of different values in the user field. One solution is to create several label legends and choose the appropriate one, but that seems a bit clunky! Ideally I would use one DV to colour both the light and the text field, but happy for it to be two separate DVs that I turn on together. Is this a thing? Any suggestions? Thanks Quote Link to comment
markdd Posted January 27, 2022 Share Posted January 27, 2022 (edited) You can do this with a Data Tag and Data Vis combined. See enclosed file. All the data tags can be applied at once or to any selected object which makes this a very quick way to do this kind of thing. Data Vis solution.vwx Edited May 19, 2022 by markdd 4 Quote Link to comment
Jake124 Posted March 27, 2022 Author Share Posted March 27, 2022 Thanks, this works well, though it's a shame we cant affect the label legend with data vis, as that would be a lot simpler! Quote Link to comment
Zrasap Posted December 6, 2023 Share Posted December 6, 2023 (edited) Hello, can you attach this file again? On 1/27/2022 at 12:42 PM, markdd said: You can do this with a Data Tag and Data Vis combined. See enclosed file. All the data tags can be applied at once or to any selected object which makes this a very quick way to do this kind of thing. Data Vis solution.vwx Edited December 6, 2023 by Zrasap Quote Link to comment
