Zrasap
    9
Everything posted by Zrasap
  1. Hello, i see Cable Tool 2022 tutorial. the tutorial says that you can't connect multiple devices in a row, is that true or has something changed in version 2023?
  2. Hello, i copy workspace from another pc and paste it to user library folder. When i try edit this workspace window with menu and palletes is empty and also all keys is empty. What i am doing wrong?
  3. I want to get this result, but I can only do it when I change the connector from the output to the input, connect it to the device, and then change the connector back to the output and already connect it to another device
  4. @Conrad Preen This is your picture from another topic, I'm trying to repeat what is indicated as "denotes bare wire ends for solder or crimp" , but it says that I need to connect the input connector to the output connector when I try to connect the panel connector to the input connector of the device.
  5. Hello, i want to connect a panel connector with rack device, and how can i do this to get the through character "-->" in the direction i need? Thanks!
  6. @Pat StanfordI made a custom truss symbol, and in change cross section menu, appointed custom structural data. And when applied this symbol in another project, structural data not imported. What i did wrong?
  7. @JustinVHYes, i run Braceworks calculation. Maybe I didn't formulate the question correctly. The fact is that structural data was not imported from my user library and I do not understand what I did wrong. Can you tell me what should I do to get it imported, or can't it be done?
  8. Hello, I made a custom truss symbol, with a custom UID, saved it in .vwx and made a custom library. When importing it into another file and trying to do a calculate all object, gray lines appear instead of colored ones. As I understand it, the UID that I made for this symbol is not imported, what can I do with it?
