I've been playing around with the cable tool today to calculate cable run lengths etc. and found VW crashing very often, when I was ending a cable run that utilised several cable paths consecutively. Loving the tool, but not the crashing part!
I'm not sure if having several cable paths that are consecutive is the best way to use the tool, but doing this in a new file worked fine with no issues, so I suspect there is a corrupt part of my existing file, which was made years ago and has come up through several versions of VW. However, all the cable paths and cable I used I put in today myself, not using any parts imported into the file from anywhere else.
I've attached a file that contains just the cable paths that I copied out of my working file, which still shows the crashing behaviour.
I have done the following, which always results in VW crashing:
Start a cable run (32/1 type) where I have placed text on stage left, run round to where the cable paths join USC, attach to main cable route that goes over the roof and drops down behind the seating rake to racks that are underneath it. When I click to complete the cable, crashes.
Start a cable (socapex) at the racks under the seating rake, drop onto the cable path that drops from the roof onto the lighting truss (text indicating this location), end it nearby. Completing cable crashes the program.
Sometimes, running a cable using only one cable path crashes VW, but usually it is fine. For example, there is a 63/3 that starts SR and follows the single path all the way to the racks and that didn't cause an issue.
Not sure whether this is a bug, or whether theres just some problematic item in my file that is breaking things.
Also, I'm finding that the cable wont follow the truss properly, but I think I have read on other posts relating to the cable path tool that often truss created in older versions of VW doesn't behave very well with the cable path tool.
Would appreciate if anyone has any experience of this and how they may have solved it.
Cheers
VW 22 SP3 (636848)
HP Envy Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz 2.90 GHz
8GB RAM
Windows 10 Home, 21H2
Cable path tool old.vwx
