fuberator Posted January 14, 2022 Share Posted January 14, 2022 (edited) Hi The one feature I really miss in Vectorworks is simple user parameters system, to be used in the oip inputs. The way it works in fusion 360 is an excellent example. Edited January 14, 2022 by fuberator Quote Link to comment
0 Pat Stanford Posted January 14, 2022 Share Posted January 14, 2022 But it does have something like that. It is called Custom Records. You can create as many records as you want with as many fields as you want. These can be accessed through the Data tab of the OIP. Or they can be accessed through a worksheet Database row so you can edit multiple objects at the same time. Quote Link to comment
0 fuberator Posted January 16, 2022 Author Share Posted January 16, 2022 Hi So how can I reference records data in the OIP? In width or height for example. At the moment, every object has to have hard coded values in the OIP boxes. Marionette is total overkill for most tasks. Here is what I mean: I might want to have all my bolts be "material thickness+nut+washer+tolerance" long. So if I change the material thickness i dont have to update every single bolt. Symbols can work, but only if all assemblies are the same. Or maybe some simple scripting like putting height*0.5 into the width and have it follow if I change the height. Cheers Quote Link to comment
0 Pat Stanford Posted January 18, 2022 Share Posted January 18, 2022 The capaibility you are asking for does not currently exist in VW. We will see what others say, but about the closest you are going to get in VW2022 will be to use worksheets so you can see all the instances of a certain object type and edit them at once or edit one and then copy/paste the value to the others. The only other option is to create things via Marionette or Script that are smart enough to recognize when other objects change and and adjust themselves. Sorry. Quote Link to comment
0 Thomas Peters Posted January 18, 2022 Share Posted January 18, 2022 Maybe the data manager will help you with this? Here is a link to a great demo Quote Link to comment
0 fuberator Posted January 24, 2022 Author Share Posted January 24, 2022 (edited) On 1/18/2022 at 9:53 PM, Thomas Peters said: Maybe the data manager will help you with this? Here is a link to a great demo Hi @Pat Stanford Thats why I posted this in feature requests and not in trouble shooting 🙂 It seems to me that there is a gap between the functionality of the OIP and marionette. Some basic scripting funtionality and a few global parameters would go a very long way to remedy a lot of repetetive tasks. @Thomas Peters Intriguing but I am not allowed to see the link, no permission cheers Edited January 24, 2022 by fuberator Quote Link to comment
fuberator
Hi
5 answers to this question
