scotthargrave19 Posted January 12, 2022 Share Posted January 12, 2022 How to model a double pitched roof using only one roof? where a roof starts out as ex. 9/12 then 12/12 on same roof face. 1 Quote Link to comment
0 KWiley Posted February 14, 2023 Share Posted February 14, 2023 @scotthargrave19Did you ever find a solution to this problem? I'm having the same issue and cant seem to find much information. 1 Quote Link to comment
0 Pat Stanford Posted February 14, 2023 Share Posted February 14, 2023 I don't think a double pitched roof is possible using the VW Roof Object. You can probably generate it using Roof Faces. 1 Quote Link to comment
0 Popular Post mike m oz Posted February 15, 2023 Popular Post Share Posted February 15, 2023 2 hours ago, Pat Stanford said: You can probably generate it using Roof Faces. You can do it with roof faces. Create all your roof faces so they have the correct shape in Plan View. Then use the Miter Roof Face Join Mode of the Connect/Combine Tool to connect each roof face to the next one. Start at the bottom most face and work your way up. File is Vectorworks 2022. Triple pitched roof.vwx 5 Quote Link to comment
0 mike m oz Posted February 15, 2023 Share Posted February 15, 2023 Kudos to the engineers responsible for the Mitre Roof Face Join capability. 3 Quote Link to comment
0 scotthargrave19 Posted March 10, 2023 Author Share Posted March 10, 2023 On 2/14/2023 at 4:17 PM, kwiley said: @scotthargrave19Did you ever find a solution to this problem? I'm having the same issue and cant seem to find much information. Just used the roof face. 1 Quote Link to comment
scotthargrave19
5 answers to this question
