34 -
Everything posted by KWiley
In the first picture you can see how my walls are broke up, I have to do this so that I can get the right look I want for my Top Plan view and also my Elevation views. No big deal. But as you can see in the 2nd pic, sometimes my brick hatch is perfect and sometimes it shows the joining line. It seems to do this randomly, I figure it's because I'm kind of tricking the software here but I figured I would ask to see if anybody else has had this problem and knows a solution. And yes I've checked that all my walls are sitting on each other perfectly, I know if your off even just a little you will get a line in Hidden Line.
How to create a shared Favorites or Workgroup file?
KWiley replied to KWiley's topic in General Discussion
@grant_PD I'm going to attempt to try this, thank you. -
I have a custom favorites file that has everything that we'll be using in our office. As of right now we each have the favorites file stored locally and every time a change is made we have to send a new copy to each other. We have a shared OneDrive folder we use to store and pull files from but i'm trying to learn how to setup our favorites file in the cloud or as a workgroup folder where we're pulling from the same file in the RM and if either of us makes a change it automatically updates. I've done some research and I don't fully understand and I don't want to do something wrong. So if anybody has the same setup and can point me in the right direction I would greatly appreciate it.
@Christopher Graye I think the way @Tom W. suggested would give us the same results and able to use the same workflow. It seems like going around the world to achieve the same result though. It was very simple being able to attach a record from the RM. As of now, I cant even remove the record that I attached this way since the context menu command is no longer there. I think I would have to revert back to a version before Update2 so that I could use the command to remove the records, or start from scratch and spend another week rebuilding our entire door and window files. I'm going to hold off for the moment and just hope that you get the command back.
@Christopher Graye So I've spent some time this morning looking into the Data Manager. I'm far from an expert and only just found out about it yesterday but I do see how to attach my existing records to the PIO's. The difference I see, and I may be missing something, is before when I could attach the record to a PIO in the resource manager, I was able to choose a description from my Record as the default for each individual PIO. That way when that PIO is used, the default description is already set for that specific object and I only have to change it in instances where needed. Attaching a record through the Data Manager gives me my Record drop down in the OIP but it adds steps where I have to choose the description for every PIO Instance, every time, instead of just being able to grab and drop, saving time.
@Christopher Graye No I haven't. Looks like I'm going to spend some time learning how to use it tomorrow though. I'll let you know how it turns out.
@Christopher Graye Well we realized early on that making changes wouldn't change existing instances. This shaped how we set up our doors and windows and what we allowed to be changed by instance on each PIO so that it coincided with our different selections in our record. This way any PIO you choose you can only make changes that will match a description in the record which you can change via drop down in the OIP to an existing PIO. We had to make a list of every possible door and window that we typically use, we compared it to the description's and what could easily be changed by instance in the drawing and that's how we came up with our description's in the record and what doors and windows we actually needed to make. We ended up with about 40 doors altogether minus 1/2 & 3/4 Glass Arch & Round Tops because the glazing disappears and turns to a solid when changing the Top Shape (I submitted this as a bug but haven't gotten a response). I can see being limited to changes not being made to existing instances on larger scale projects. We haven't had any issues so far with this workflow but it did take some time to set up so that we don't run into those issues. Everything we've built so far is to be as streamlined as possible, we wanted to be able to just grab and go as we're drawing without having to stop and make a lot of changes and so far it's worked out great. It really surprises me that this wasn't set up to be this way. We really hope that VW decides to add the records to PIO's, at least just for doors and windows because we really do love being able to customize our own descriptions with records.
@Christopher Graye Not sure if these guys are actually affiliated with Vectorworks but this is the video, around 42 min.
@Christopher Graye This is surprising to hear, I'm not sure if I understand completely if I'm doing something right or wrong because I learned how to attach a record to a door or window from a VW video. I did notice that attaching a record wouldn't change existing instances. Everything I've done I've done for both doors and windows but while I'm explaining I'll just use doors for example. I started off by making a Record with a list of every possible variation of door and how we want it to be described on the schedule, I made each description a drop down so that it can be chosen from the OIP after the fact in case something like material needs to be changed on a single instance. After making all of my different door Plug-Ins, I right clicked each door in the Resource Manager, selected attach record, added my record to the door, then selected the default description for the door to come into the file with. I then added my Record to my Door Schedule, then added my Schedule to the appropriate Sheet Layer in my Template file. I thought this was the right way of going about this to customize our schedules to read the way that we want them to. I've spent almost 1 yr now setting up Vectorworks for our office so that its completely streamlined and customized to our office standards and style. As it is now, you place all your doors and windows while you're drawing, add your data tags and the schedules are already sitting on the sheet layer completed ready to print. It took a little time to set up but it's a HUGE time saver and one of our favorite things about the software. Now that "Attach Record" has been removed, our doors and windows and everything we've set up so far is still working as it's suppose to but now if we build any new door or window Plug-Ins there is no way for us to attach our record so we will have to manually type the description in the Schedules.
Yes, I updated as soon as it came out. I was right in the middle of customizing my door file when the first problem with the attach record happened, I reverted back to update 1.1 to finish what I was working on. After running into the door glazing issue and the column issue this morning I went back to update2 and all 3 problems are still there. I submitted bug reports on all 3, the attach record bug has been confirmed. The other 2 I just submitted this morning. I'm currently downloading 2023 again so I can actually get some work done.
Anybody else experiencing problem after problem with 24? The attach record missing in RM has been reported as a bug. Glazing turns to a solid panel when Segment or Round Top is selected on doors and no control over the mid style. All of my custom columns from 2023 won't let me change the height now, it will try then just go back to default.
Not sure if it's user error, a bug, or VW just won't do what I'm trying to do here. If I have a 1/2 glass or 3/4 glass door and I change the top shape to Round or Segment the Mid Stile moves up to center and the glazing in the top panel goes away and makes it solid. I still have the option for Glazing in top panels so it makes me feel like it may be a bug. Also I'm not sure why the Mid stile moves up to center and doesn't give me control to move it up or down. Any help or guidance here from you long time users is greatly appreciated.
Did you try doors or windows specifically? It seems like a bug to me but I want to make sure. I've tried everything I know to do on my end.
@Mark Aceto I did refresh Libraries, no change. It looks like it's isolated to doors and windows, attach record still shows on all other symbols I've tried so far, including symbols I've made and VW symbols. To rule out an error on my end with my custom doors, windows, or template I opened a blank document and put some VW doors and windows in it and attach record still isn't there.
Well, thought all issues were resolved. As soon as I dove back into work I noticed the Attach Record selection after right clicking an object in the Resource Manager is now missing. It was there the last 2 days I know for sure, I installed update2 this morning. Anybody else see this issue?
I had some other issues after installing VW2024, I installed update2 this morning and after resolving my first issues I started to get back to normal work and noticed the Attach Record selection after right clicking an object in the Resource Manager is now missing. Is this an issue with anybody else or did I do something wrong? Please help.
@Mark Aceto @Amanda McDermott I found what has seemed to fix our issues so far. I saved my workspace again in 2024, I deleted my Favorites files from the resource manager, I then opened all my favorites files individually and saved them in 2024, then I added them back to my Favorites in the resource manager. VW now opens in 24 seconds instead of 1 min 40 sec. Navigation is back to normal and clunkiness is gone. My door file is still a bit slow but I didn't realize how heavy the file has gotten. Not having any of the slowdown problems in any other files now, updating all our favorites files to 2024 fixed the issues on mine and my coworkers machines. Thank you, if I run into any new issues I will def chime back in.
@Mark Aceto I don't even know where to begin on a bug report. The software as a whole is just really slow and clunky feeling now. You right click and it takes 30 seconds before a window opens or you place an object and it takes 30 seconds to be placed in the drawing, etc. I wanted to make sure there wasn't any performance settings suggestions inside the software or on my graphics card that I could try first that I already haven't. Or if maybe there is any known issues with workspaces or 2023 files coming over into 2024.
@Amanda McDermott It does seem like all the issues are with Windows users. Ours are very slow on startup also, which I'm not too concerned with if I can get the software to perform right once opened. @michaelkMine is - 12th Gen i7, 32GB, NVIDIA Geforce RTX 3050. My coworker - 11th Gen i9, 96 GB, NVIDIA Geforce RTX 3060 Ti. Both Windows 11. We've both made sure VW is using our NVIDIA graphics cards and checked for driver updates.Neither had any trouble before switching to 2024, we both are having the same issues so I don't believe its hardware. It's so slow we're not even able to use 2024 for production right now. I'm going to PM you the file I've been working on in 2024. @Mark Aceto I'm working in the same files I was working on in 2023. I've mainly just been continuing my work with custom doors and windows since updating to 2024 and any time I place an object in a wall it takes 28 seconds before i can go to the next. The software is very slow and delayed in everything though, its not isolated to doors and windows.
2024 has been VERY slow and clunky. 28 seconds between making a change or adding an object before my next click. Installing Update 2 now. Very concerned about the software at this point.
Giving up om 2024 and looks like 2023 from now on
KWiley replied to MartinFahrer's topic in General Discussion
Our office is also experiencing a major slow down with 2024. We just switched to VW about a yr ago and were very happy but after spending almost a yr getting the software setup for our office the way we want, we are very nervous with the slow down and clunkiness of the program now. I timed the time it freezes before being able to continue after adding an object and its right at 28 seconds. 2 of us in the office both using Windows but have different machines having the same issues. 2022 & 2023 were great on these same machines. Are there any suggestions to speed up the program? It doesnt sound like yall even see this as a problem so are we not looking forward to a fix? -
Merge is enabled in OIP but the extrude doesn't merge
I'm curious to know if theres any different ways to create wing walls. Using the wall edit tool doesn't allow me to stretch the wall past its edge so what i've been doing is creating an extrude of the wing and placing it at the top of the wall under the eave. My problem is when I create my elevation views in hidden line now I have the wall line running between the wall and the wing. Is there a way to create the wing where its actually apart of the wall and if not is there any kind of work around? I don't show the wings on the Floor Plan, only on the Elevations.
