ErichR Posted October 27, 2004 Share Posted October 27, 2004 If I stick a PIO window into a wall, I no longer seem to be able to drag it out of the wall or to move it within the wall by dragging it. Click on the window object, and the wall length changes, or the wall changes position dramatically. What gives? [ 10-27-2004, 05:00 PM: Message edited by: ErichR ] Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted October 27, 2004 Vectorworks, Inc Employee Share Posted October 27, 2004 What version of VWA are you using? Quote Link to comment
ErichR Posted October 27, 2004 Author Share Posted October 27, 2004 I pasted the wall with its windows into a different drawing file, and the PIO behaved normally. But the problem isn't unique. It has happened before. Quote Link to comment
BisbeeBlue Posted October 27, 2004 Share Posted October 27, 2004 I've had similar behavior with 11.01. The object seems "stuck" in the wall. I can only move it by nudging. Odd Quote Link to comment
ErichR Posted October 29, 2004 Author Share Posted October 29, 2004 Pretty sure this is a bug in 11.0.1. Seems that after a while, working with a wall and a simple window, walls and PIOs attached to them become somehow infected with a stickiness. The file appears to be afflicted. Paste the wall into another drawing file and it works fine. Quote Link to comment
BisbeeBlue Posted November 2, 2004 Share Posted November 2, 2004 Yeah, I pasted the wall into a new drawing and it started working again. Strange Quote Link to comment
ErichR Posted November 4, 2004 Author Share Posted November 4, 2004 This is truly a BIG problem, unless it's the result of some simple setting that I'm not aware of. It's surprising that there has been only one other acknowledgement of this issue. The problem is that if a wall is fooled with enough (moving PIOs around manually), eventually, it seems, the wall can't be touched with the cursor without the wall going haywire. You can select the wall by surrounding it with a marquee, but yhou can't select the PIO. Sometimes the wall shrinks to a fraction of it's size, Sometimes it sticks to the cursor, sometimes it's ends shoot off into space. I remember the latter happening with VW several versions ago. Quote Link to comment
ErichR Posted November 11, 2004 Author Share Posted November 11, 2004 Anyone else weighing in here? Quote Link to comment
CipesDesign Posted November 12, 2004 Share Posted November 12, 2004 Hi ErichR & All, I have not seen this behavior in quite a while. The fact that the objects behave normally in a new file lead me to wonder: were the files in question originally created in an earlier version? Did you create new templates and workspaces when you upgraded to 11 or did you copy (or drag) your existing ones into 11? Quote Link to comment
ErichR Posted November 28, 2004 Author Share Posted November 28, 2004 The files in question probably originated in prior versions. I rarely start entirely new documents, since class and layer structure, not to mention preferences, dimensioning, symbols, etc., etc. become valid templates to run with for new projects. Should one (have to) start documents afresh with each new VW version? Discussed this issue briefly with Robt.Anderson at Build Boston. He suggested using this script on the errant object: reset object(fsactlayer) [ 11-27-2004, 07:57 PM: Message edited by: ErichR ] Quote Link to comment
Jonathan Pickup Posted November 29, 2004 Share Posted November 29, 2004 if the object works well in a new layer, you might try the trick for saving a corrupt file available from my web site: http://www.archoncad.co.nz/resources/resources_tips.php look for the tip from October 2002. Quote Link to comment
