techdef Posted July 28, 2021 Share Posted July 28, 2021 Hi all - been doing SDs for a 7 sided flag lot. Finally have a preferred orientation for the main part of the design. Is there a way to 'flatten' or 'codify' the plan rotation? Ive saved several views for things, and now would like one of them to be the new normal. thanks Quote Link to comment
Pat Stanford Posted July 28, 2021 Share Posted July 28, 2021 I think you are going to want to select all the items on the design layer and rotate them by the desired angle. If you set your layer options to Modify Others then you should be able to rotate all the layers at the same time. Rotating the design layer will mess up any saved views and viewports that you might have already set up. Quote Link to comment
MarcelP102 Posted July 28, 2021 Share Posted July 28, 2021 Take a look here Select File > Document Settings > Georeferencing ~ Angle to True North I think this method will not mess up your viewports. Give it a try and let us know. Quote Link to comment
techdef Posted July 29, 2021 Author Share Posted July 29, 2021 Sadly this did nothing. I'm already Georeferenced FWIW. Quote Link to comment
techdef Posted July 29, 2021 Author Share Posted July 29, 2021 Pat, since I'm just in shematics, there arent really any viewports yet worth saving. Not having to set rotation on all the new ones would outweigh... I'm already georeferenced, so perhaps this isnt possible, but it seems like there should be a way to set a user grid of some sort Quote Link to comment
Pat Stanford Posted July 29, 2021 Share Posted July 29, 2021 I think Rotated Plan View coupled with saved views is probably your best bet if you are georeferenced. 1 Quote Link to comment
