What is happening with wall joins in horizontal section viewports?
Ride
Is there a reason wall joins don't appear correct in horizontal section viewports? See attached screenshots, one from the design layer, and one from a section viewport. Why do the wall randomly join, or not join?
Thanks
VW 2021SP4 Architect, InteriorCAD
Mac OS Mojave
3 answers to this question
Guest Frank Brault
Just a guess since I haven't seen your file:
It could be that you need to manually join the wall joins that are failing here...
hth...
Also, check the Merge Cross Sections option under advanced properties?
The walls were joined manually many times, but it's like playing whack-a-mole. Fix one side then the other doesn't render properly.
But your suggestion about merging cross sections worked. At least the "merge structural objects with the same fill" worked great.
Thanks!
