Unable to delete Polyline
10 answers to this question
Have had similar issue before when working with large curves that had been trimmed.
If you can select the line try converting it to something else, e.g., a Nurbs Curve,
Modify > Convert > Convert to NURBS
then see if you can delete it.
Posted (edited)
Thank you.. for a moment I was relieved, because after I converted the inner curve I was able to delete it. BUT, when I did the same with the outer one and pressed 'delete' the inner curve resurfaced again and the outer remained as it is. I tried it several times. 😮
Edited by Kristina90
