Andrew Skeoch 0 Posted February 23 help. when i enter a command I have to next mouse click to enter. any solution? Quote Share this post Link to post
0 Andrew Skeoch 0 Posted February 23 To be more specific. If I draw a line, end to end. won't appear unless I move mouse. . Never happened before Quote Share this post Link to post
0 Pat Stanford 1,631 Posted February 23 Have you restarted VW and the computer? Quote Share this post Link to post
0 Andrew Skeoch 0 Posted February 24 yes was think about reloading. using vector for almost 20 yrs. To finish a command I need to zoom Mouse. For example if I high light object to delete and press delete I then need to move mouse for action. Mac book pro pad and or blue tooth mouse. Quote Share this post Link to post
0 Pat Stanford 1,631 Posted February 24 I have not heard of this problem before. Two things to check. 1. If you normally use Click/Drag drawing, check VW Preferences and make sure it did not accidentally get changed to Click/Click drawing. 2. If you are still having a problem, maybe boot into a different user account (or create one and boot into it) and try and run VW there. If it works properly there then it is likely a problem with your user folder. If this solves the problem let us know and we can talk you through fixing your user folder. Or search the forum for one of the hundred of threads that talk about it. Quote Share this post Link to post
0 michaelk 537 Posted February 24 @Andrew Skeoch What mouse are you using? What kind of computer? What OS. What version and SP of VW? I have seen this and it's really annoying! On my i9 16" MacBookPro, OS 10.15, VW 2021, SP3 with one specific mouse I see exactly this. 1 Quote Share this post Link to post
help.
