techdef Posted October 17, 2023 Share Posted October 17, 2023 I have my parapet wall style set to display textures by Object not by Component. Within the wall, the Exterior Face components are textured By Class. That way in 3d views it simply shows all 3 sides as whatever class the wall is drawn on ie: Stucco-Color-4 Quote Link to comment
techdef Posted October 17, 2023 Share Posted October 17, 2023 That said, when I DO want to show a metal cap, I have another Parapet Cap wall, using the appropriate classes/textures, which defaults height-wise to Parapet Wall bottom, and Parapet Wall +2" for top. Therefore I draw my parapet wall as normally, then duplicate and change style to Parapet Cap & it automagically pops up a tad & recolors. 1 Quote Link to comment
Mika I Posted February 27 Share Posted February 27 Has this really not been solved yet? Everyone stills uses a multi-step solution to end walls? It seems rudimentary to give people the ability to end the wall without having to model flashing (why is flashing also not a tool like it is in Revit?) Having to create extrusions might be simple, but editing it when you want to also edit your wall when you're in SD/DD phase is very cumbersome. Quote Link to comment
line-weight Posted February 28 Share Posted February 28 15 hours ago, Mika I said: Has this really not been solved yet? Still has to be done manually as far as I'm aware. Quote Link to comment
