worksheet sum
Hi ALL!
Anyway i can sum all the values from my led Wattage records?
I´ve tried quite a few times and ways to use the sum value,,, but only get the module wattage not really the full array..
and if this is not to much to ask can i add to that sum an expression so i get it in Amp instead of W.
sorry.. just learning how to use reports and this is amazing but a little difficult to use since i´m a long time excel user!
thanks in advance
If you have the number of modules in the array then you should be able to just multiply the wattage per modules X number of modules to get the total wattage.
I belive Watts = Volts x Amps, so to get Amps, just divide the total wattage by the voltage of the system.
If you need more help post a file or at least screen shots showing the worksheet and the database header row formulas so we can see what you are trying to do.
  • 6 months later...
On 3/27/2023 at 8:20 AM, Pat Stanford said:
The only trick to the above is that what you pass to the Value function must be characters that make up a number only. No unit marks, no suffix, no prefix, no extra spaces.
No Thousands separator.
Thanks for putting this in writing Pat.
I wish this was more clearly stated in the help pages... If they had opened with "using number values only - no thousands separator".
I have had so many instances in the last 4 years, struggling to get a simple "SUM" formula to work, banging my head against the proverbial wall... all because I had a thousand separator!
