jpccrodrigues 22 Posted November 22, 2020 Hi guys, good morning, I've been trying the data visualization tool on planting and irrigation. Do you have any experience with DV in pipes? My idea is to create a DV to represent with different colors the pipes according to its nominal size (2" blue, 1" red, 1/2" green, for example) or its calculated velocity (red over 1,52 m/s). The thing is that I'm not being able to reach those record data. None at all, to be fair, concerning pipes. Did someone had the same problem? Any workaround? I upload my "test file" so you can take a look. Thanks!!! Untitled1.vwx Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 @jpccrodrigues Attached is I believe what you are looking for.Set the criteria to Object Parameter then look for Pipe Nominal size. Because it is a line you need to set the line color of the DV to apply attributes then set the pen to the color needed. Hope this helps. Fixed.vwx Quote Share this post Link to post
jpccrodrigues 22 Posted November 22, 2020 1 hour ago, bgoff said: @jpccrodrigues Attached is I believe what you are looking for.Set the criteria to Object Parameter then look for Pipe Nominal size. Because it is a line you need to set the line color of the DV to apply attributes then set the pen to the color needed. It seems that I might have a problem with this. Trying to see you DV script: Cannot edit or even open it. Any clue about this? Thanks!!! Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 what version of VW do you have? Are you using Designer or Landmark? Quote Share this post Link to post
jpccrodrigues 22 Posted November 22, 2020 Vw 2021 Landmark with Service Select Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 When you set the perimeter in a New Data Viz do you not see object parameter and Pipe? Quote Share this post Link to post
jpccrodrigues 22 Posted November 22, 2020 I reach the menu Pipe, but no options Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 Interesting. Try a restart and let me know if that helps. This may have to go to tech support. I am monitoring this chat today. Let me know if anything happens after a restart. Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 Also check in the Plugin manager to see if you have "Irrigation Pipe" in the list. It will be under the built in tab. Quote Share this post Link to post
ericjhberg 352 Posted November 22, 2020 Just an FYI, depending on version, there is also a data visualization bug associated with Irrigation Objects that may, or may not, be solved yet. I have submitted the bug in Beta testing and still haven't determined if it's fixed. Essentially the bug is that once a data visualization is set up, say for pipe size or for output pressure, the data visualization appears correctly upon first setup, but as soon as the design changes, the visualization doesn't dynamically update or change with the changes in parameters. The only workaround I have found was to save the data visualization, remove it from the current drawing, and then re-apply it from the saved visualization library. 1 Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 of course you would find that! Do you test everything working backwards in a mirror on a Thursday with the wind blowing from the east? 🙂 Good to know I will test. Lets see what JP comes back with. 1 Quote Share this post Link to post
jpccrodrigues 22 Posted November 22, 2020 @bgoff I have it on the list, but no parameters inside: Restarted and no changes. Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 @ericjhberg what version are you in? I am adjusting JP's file and it seems to work but at this moment all I am doing is adding Pipe. Is there more in regards to changes to the design that you might be referring to? Also could you PM me the VB #. Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 @jpccrodrigues There won't be as it is Locke but it is in your list that's a start. Have you tried the restart? Quote Share this post Link to post
ericjhberg 352 Posted November 22, 2020 @bgoff I am fluctuating between 2020 and 2021. It may be fixed in the newest SPs, but I haven't tested it again. When I said changes to the design, I meant something like if the Input/Design pressure changed, and thus pipe's resized or the output pressure changes. The corresponding data visualization doesn't change to show any changes in pipe size or output pressure...I just stayed the same as when the data visualization was first applied. 1 Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 @ericjhberg ill test that after lunch. Quote Share this post Link to post
jpccrodrigues 22 Posted November 22, 2020 @bgoff Tried restarting program and pc, problem persists Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 I will forward to Tech Mon Morning. Quote Share this post Link to post
bgoff 142 Posted November 22, 2020 @jpccrodrigues What version, SP and Build # are you on? Quote Share this post Link to post
jpccrodrigues 22 Posted November 22, 2020 @bgoff Sent you through direct message Quote Share this post Link to post
bgoff 142 Posted November 23, 2020 @jpccrodrigues We believe it is from an old workspace that was corrupted or modified incorrectly. Could you try editing the workspace? Got to Tool>Workspaces> Edit Current Workspace. then under tools tab (on the right hand side) select tool sets>irrigation remove the pipe tool and then find it in the left column and replace. Also if you are using a custom workspace and it it listed try switching to the Landmark (Stock version) this would only be if a different workspace is showing. Quote Share this post Link to post
jpccrodrigues 22 Posted November 23, 2020 Installed new SP2, tried both of your suggestions, no changes... Quote Share this post Link to post
bgoff 142 Posted November 23, 2020 contact Tech. They can do a once through with you to see what they can find. Quote Share this post Link to post
jpccrodrigues 22 Posted November 24, 2020 On 11/22/2020 at 6:01 PM, bgoff said: what version of VW do you have? Are you using Designer or Landmark? Problem solved by our local supplier. It was an interference with another local plug in. Thank you very much for your help!!! Quote Share this post Link to post
