Hello everyone,
I do not know why when I export a pdf from a sheet layer the quality is horrible lately.
I am using VW 2019 on a iMac. What did I touched to change the settings? the sheet layer is at 150pdi and usually is enough, actually for 2D drawings I usually use 72dpi, but since this morning when I export/print a pdf the quality changed.
Any suggestions? I have already tried to change the dpi in the sheet layer or the general document settings but nothing happened.
new.pdf Original.pdf
6 answers to this question
If you usually have 2D (Vector) data,
72 DPI may be enough, as PDF usually has also Vector data,
which is scale independent and always sharp.
Therefore I think you may have accidentally activated "Rasterize"
This will lose all Vector data and safe as an image file.
(Sometimes a valid workaround to avoid visibility problems and such)
In case of a rasterization, the 72 or 150 DPI may be too low to
show a drawing as a raster image in PDF.
There should be a checkbox for Rasterize de/activation in your
PDF Print or Publish settings, top right.
it is the first time that I see this function in VW and I do not really know how it works/what is it supposed to do, but unfortunately it doesn't seem to be the problem, I have the exact settings as you, or am I missing something?
@Giulio Can you just confirm for me what exactly looks worse on your end? When I am comparing these PDFs, they have some differences in geometry and some line weights, but the overall quality seems to be identical?
I think I have "solved" the problem. If I export the pdf the final pdf is perfect, if I "print" the pdf the quality is lower (I use Preview to see the pdfs).
it is not the perfect solution but at least I have one...
