data tag object parameters
TKA
2 answers to this question
It appears that the Stair tool uses internal storage to hold the data for the object rather than storing it in a Parameter record. That means that the data is not accessible to the Data Tag.
You might be able to attach IFC data and use the Stair-Common or Stair-Flight-Common Pset to report with the data tag. But that is an additional step.
You probably want to post in the Wishlist forum for access to the Stair Object data by Data Tag.
thanks, it is strange though that for instance in simple stair I can get R&T size and fl to fl, not the number of risers though, in new stair tool only fl to fl and a lot of other parameters which I doubt anyone uses. Seems like an unfinished project with stair tool (again).  I will post it in the wish list.
