stevewrightni Posted October 7, 2020 Share Posted October 7, 2020 Hi, Im using vectorworks 2021, purged the document to reduce the file size and now half the document is gone! all layers and classes appear to be turned on I thought purging only removed things that were unused like unused layers and classes? Quote Link to comment
0 rDesign Posted October 7, 2020 Share Posted October 7, 2020 Have you tried using Undo to get back the objects that were deleted? That or restore to saved version (assuming you hadn’t saved the file). Most likely when you ran the Purge command, under ‘Other Items’ you had also checked ‘Objects Outside of Page Boundaries for’. That option can be very dangerous and should only be used with caution. Per the Help File that ‘Objects Outside of Page Boundaries for’ option will: Quote Deletes any objects that are totally outside the page boundaries; if an object is partially within the boundary, it will not be deleted. Objects can be deleted from the active layer only, from all design layers, and from all sheet layers. 1 Quote Link to comment
0 stevewrightni Posted October 7, 2020 Author Share Posted October 7, 2020 i purged, saved and closed as i was having other graphical errors following a publish!!!! and the autosave saved the purged file! why would there be any option to have things deleted in a purge option?!?!?! Quote Link to comment
0 Ride Posted October 9, 2020 Share Posted October 9, 2020 For a while I had a problem with the purge command deleting everything in my drawings, so I quit using it for a while. I just checked, and it's working normally again. I haven't changed any purge settings lately. I really hope you didn't lose a ton of work! I'm on VW2020 SP5, mid-205 Macbook Pro, Architect, InteriorCAD. Quote Link to comment
stevewrightni
Hi,
3 answers to this question
