Kevin R Posted November 4, 2004 Share Posted November 4, 2004 Hey there. Thanks in advance for the patience to a new user. I'm wondering how I can get an outline around large masses of perennials without the actual plant symbols/circles showing? I want to show just "drifts" for the different groups, while retaining plant group info, plant tags, etc. At the moment my drawing is a million overlapping circles. I figure there has to be a way to do this, but vegetation line doesn't seem to apply... Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted November 4, 2004 Vectorworks, Inc Employee Share Posted November 4, 2004 Look at the Set Plant Style command. If you choose "No Sketch" and enable styling on a plant group, it will be "merged" if the circles are overlapping. Quote Link to comment
Kevin R Posted November 5, 2004 Author Share Posted November 5, 2004 Got it Robert. New problem. Plant tags don't display this way, unless I'm missing a setting. Also, the styling added weird filled surfaces on my shrub symbols. Quote Link to comment
Kevin R Posted November 5, 2004 Author Share Posted November 5, 2004 And yet another. I could maybe deal with no styles, but upon showing my plant tags now, those groups (SOME, BY THE WAY, NOT ALL, very quirky) are merging in ways that are far from what I want. Kill me, please. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted November 5, 2004 Vectorworks, Inc Employee Share Posted November 5, 2004 They merge in order of placement. Plant tags should display, if they're defined as part of the plant (and enabled in the Info palette.) Quote Link to comment
Kevin R Posted November 5, 2004 Author Share Posted November 5, 2004 Robert, I hate to be "that guy" and bombard you, but in working with your suggestion of adding a style to my groups, I now get a script error. "Error 1560 52. You must ALLOCATE the dynarray before using it. It literally gets worse as I go. VW needs more time in R&D. OK. What I need to do is: Have a large overlapping mass of simple circle symbols turn into just the outline, with a plant tag visible.Ideally a graphic enhancement like vegetation line would be easily added as well. I need to do this without weird filled polys appearing on every plant group, some tags hiding some not, etc. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted November 5, 2004 Vectorworks, Inc Employee Share Posted November 5, 2004 I think this is a learning-curve and training issue. Frankly, a Tech Support board is really not efficiently set up to substitute for training. Send me your email, though, and I'll send you an example document of plant styling that may give you some ideas of how to do what you want. randerson@nemetschek.net Quote Link to comment
Viper x Posted November 5, 2004 Share Posted November 5, 2004 I too would interested in that example Robert, I will e-mail you also if that is OK. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted December 22, 2004 Vectorworks, Inc Employee Share Posted December 22, 2004 JGTLA, which 2D symbol are you using for the plant definition? One of the standard ones? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted December 22, 2004 Vectorworks, Inc Employee Share Posted December 22, 2004 If you want a "drift" only, create a 2D plant symbol (or modify one of the existing) to have a zero line weight for its boundary. Then place a cluster of them and style with "no sketch". Quote Link to comment
JMTLA Posted December 23, 2004 Share Posted December 23, 2004 Hoping that someone could help me out with this topic. I have followed the above instructions for creating a "drift", but when I set the plant style and select no sketch and my plant style is enabled, nothing happens. If I select cloud in the plant style, the result is a drift around my overlapping grouped plants with all the plants showing, no merging is occurring. I'm using MS OS and VWL 11.01. Thanks for the help Quote Link to comment
JMTLA Posted December 23, 2004 Share Posted December 23, 2004 Robert- I using a standard 2d symbol that is in my plant catalog. Quote Link to comment
Thom Posted December 23, 2004 Share Posted December 23, 2004 Robert I would like to make a comment here that I have made several times to marketing and sales. At this time there is no specific training outside the cd's for Landmark. Quote Link to comment
Marietta Posted January 31, 2005 Share Posted January 31, 2005 What I do is use a 'very' small circle, dot, or cross as the plant symbol - much smaller than the spacing of your plants - fill in your area for that plant type using the place plant tool and with none in the polygon display (Object Info palette). Then I draw an polygon outline and use the plant line tool to suggest the plant bed. This works well for perennials or shrub beds on drawings with a small scale (1:500 for example). Make sure the symbol is as simple as possible. I hope this helps. Quote Link to comment
