Thom
Content Count
538 -
Community Reputation
14 GoodAbout Thom
Rank
500 Club
Personal Information
Occupation
Landscape Architect
Homepage
www.ecoplan.us
Location
Wenatchee, WA
Recent Profile Visitors
Why are creating retaining walls so confusing?
Thom posted a question in Wishlist - Feature and Content Requests
The tag line says it all. Never used to be so hard. -
I would like to see an irrigation tool that would allow the selection of several irrigation heads and then automatically figure out routing and pipe sizes. I worked on this several years ago with a competitor.
- 1 reply
- 1
thks - it worked, 20 yrs with VW and still learning
I need to create to Plant Lists for the same dwg. One for Mitigation Plantings, and the other for General Landscape. I have the plants in different classes and Layers. Is there a way to do this with a preformatted report or do I need to create a custom report using the specific classes and layers. thks
I often need to work with Civil 3D import and export. I have attached three files. One is the orginal file from the Civil. The second is the file imported directly into VW. The third is a file that has taken 3 hrs to get workable. My client asked me to take the file and create a graphic. I had to completely recreate the road and grading plan as their is no way for VW to read the complete grading plan. Also, 3D symbols must be broken down. Poly line simplified considerably so VW can deal with it. 2018-10-17 BLUE WATER-PE-2.dwg 2018-10-16 BLUE WATER-PE-2.pdf Ecoplan 23b Oct.vwx McDonald align 23 Oct PLC.pdf
To add to this - would be nice to be able to use road sections similar to autocad. (ditches, cross slopes, curb, gutter, sidewalk, side slopes) I presently will create my own rough cross section (contour line that resembles the result I want and cut and past every 25' and modify the z component.
I am having the same issues. Dreading the start of another ballfield project.
- 8 replies
- irrigation
- landmark
(and 2 more)
Tagged with:
Single File vs. Referenced File Workflows - Landscape Architecture
Thom replied to ericjhberg's topic in Workflows
@ericjhberg I agree totally. When much of my work creates extremely large files, especially grading and irrigation. My machine is no slouch. It seems (at least in my way of thinking) that there must be a way to use less processing power. Other competing programs do not seem to have this issue. -
Just need to make sure additions do not require more resources. I have a new hot machine and when I get into 5 plus acre irrigation projects, the resource demand really bogs the machine down. Either that or figure out how to write more efficient code.
I would like to see the ability to select a valve and have all components show selected.
Also, would be nice to be able to create vertical curves
I would like to see the ability to change Road Grade Limits to be assigned station to station and side to side within station to station constraints. Would allow for retaining wall simulations in one spot and a graded slope in another. More flexibility
I need to be able to send road layouts, lot lines, pads, etc to civil engineers who use Civil 3D. Anyone have pointers. I find it increasingly difficult to get them my planning info.
So what you are saying is that a quad core machine is no better than say a dual core and that processing speed is most important.
Can VW access more than one core on a quad core machine?
