Biscontin Posted July 17, 2020 Share Posted July 17, 2020 Is it possible to paste an image (let say I open a Jpeg in Mac Preview, select an area of the image, Ctrl+C to save it in the clipboard) in JPEG and not in PNG? When I Ctrl+V the clipboard VW paste in always in PNG format... Quote Link to comment
zoomer Posted July 17, 2020 Share Posted July 17, 2020 PNG is the standard format VW will convert images when importing. (PNG is lossless) But there is a VW setting that will allow you to change to lossy JPEG format, to save file size. But that will be the standard for all images. If files size doesn't really matter, you should not care much about the standard PNG concersion. Unlikely but could also be that there are any Settings in Preview which will default to PNG for Clipboard (?) Quote Link to comment
Biscontin Posted July 17, 2020 Author Share Posted July 17, 2020 "But there is a VW setting that will allow you to change to lossy JPEG format, to save file size. But that will be the standard for all images." yes, please tell me where to change this... thanks! Quote Link to comment
Pat Stanford Posted July 17, 2020 Share Posted July 17, 2020 Vectorworks Preferences, Edit Pane, Default Compression. Quote Link to comment
zoomer Posted July 17, 2020 Share Posted July 17, 2020 Had to search for it .... But it is in : VW Preferences > Edit >> Default Compression PNG / JPEG (upper middle on right hand side) Quote Link to comment
Biscontin Posted July 17, 2020 Author Share Posted July 17, 2020 Unfortunately does not work... see video. I quit/restarted VW, nothing... not working. Screen Recording 2020-07-17 at 14.53.17.mov Quote Link to comment
zoomer Posted July 17, 2020 Share Posted July 17, 2020 Hmmh, looks like it only works if you File > Import Image > Dialog PDF/JPEG I also do not find a related Setting in Preview, Finder, Digital Images, ... (Maybe I have seen such in Linux) Quote Link to comment
