kodama@austin.rr.com Posted January 4, 2006 Share Posted January 4, 2006 I need to model some columns with spiral flutes in VW12. I have had no luck. Can some one steer me in the right direction? Wayne Locke Quote Link to comment
grant_PD Posted January 4, 2006 Share Posted January 4, 2006 sounds like a job for nurbs/ extrude along paths.... Quote Link to comment
islandmon Posted January 4, 2006 Share Posted January 4, 2006 1) Determine Flute Cycle Rate = degrees of turning within column 2) Determine Flute Angular Separation = frequency of fluting per cycle. 3) Divide, FCR / FAS to determine number of nodes 4) Divide column length by number of nodes to get pitch angle. now you can : 5) create a single 2d section with the fluted profile then convert that to NURBS curve. 6) Dup & Rot per nodes & pitch angle 7) Loft the nodes of one dihedral to create a NURBS Solid Here's one I just created for you using a 15? separation @ 90? cycle, note the 6 blue NURBS sections rotated 15? each. This module can then be stacked as symbols to create multiple cycles of 90?: Hope this helps ; ) Quote Link to comment
kodama@austin.rr.com Posted January 4, 2006 Author Share Posted January 4, 2006 Islandman, That's precisely it. I have some questions? What is the Flute Cycle Rate and how did you determine it? Does a 90? Flute Cycle Rate mean that a flute spirals 1/4 of a full turn? I use the term pitch to mean the column length reqired for a complete spiral, i.e 12" pitch means a complete spiral in 12". Does this fit into your explanation anywhere? I also don't understand "Flute Angular Separation = frequency of fluting per cycle". If you could explain your example a little more to me I would appreciate it. I'm an English major/Woodworker not a mathmatician or engineer. Thanks, Waayne Quote Link to comment
Kevin Posted January 6, 2006 Share Posted January 6, 2006 EJ, this is amazing work. My question is how long did it take you to make this? It would help me understand how complex an operation this process is. Quote Link to comment
islandmon Posted January 6, 2006 Share Posted January 6, 2006 As you can see, it's all really very quick & easy ... requiring only the original fluted section as a NURBS curve duplicated & lofted to any degree of twist. In the illustration I use 15? increments with a pitch height= 1/2 of the radius of the section: Quote Link to comment
Travis Posted January 7, 2006 Share Posted January 7, 2006 Thanks, Armstrong, this tutorial is very helpful. Wonder if you might post it on the TechNotes/HowTo board. Happy New Year!! Quote Link to comment
kodama@austin.rr.com Posted January 8, 2006 Author Share Posted January 8, 2006 I made a, in this case 6" X 36" column, with a solid extrude. Then I made a line and used the "spiral-helix " command and "extruded along path" a 1" radius circle, then did a duplicate array and solid subtraction. The result was very good and fairly fast. I am less familiar with lofting nurbs but was less satisfied with the results. If I attempted to loft vertically more than 6" I got the beginning of an hourglass shape and there was a lot of duplicationg and rotating. I liked the approach and would like to know if you could make the top and bottom nurbs, rotate the top 180?, and loft it without getting the hourglass. Wayne Quote Link to comment
