Cloud publish changing date format in title block
Hi all,
I'm using Cloud Publish to render some PDFs of a job.  When I publish them the plot date changes from UK format to US format.
The plot date in my title block is in UK format as below DD/MM/YYYY:
890051768_Screenshot2020-05-30at17_43_46.thumb.png.41852d8bb5e7141676d0cba560ecc22f.png
I tried changing to manual entry from Auto.
1580063005_Screenshot2020-05-30at17_44_05.thumb.png.4f145ef6b97c52e38632a982ac04e2ce.png
They come back every time as MM/DD/YYYY:
301276858_Screenshot2020-05-30at17_46_05.thumb.png.2c221cf26f8f11d18bae619148cca36f.png
Any thoughts much appreciated!
Cheers,
Cookie
Hello @Cookie_NZ,
I have tested using Manual Plot Date format and did not have any changes in my date value. Could you verify that you are using Manual Plot Date Format in the TBBs you publish and you have the correct Current Plot Date manually set before publishing? Using Manual format should not change the value of the plot date.
Best Regards,
Nikolay Zhelyazkov
  • 4 years later...
Hi all, jumping onto this 4 year old thread with a similar question, I had the same issue as Cookie but managed to work around it by using the Auto - Custom plot date format. Cloud services seems to respect this format. However, when I print my PDF's it displays the date as yesterdays date, not todays. So for example I printed some PDF's today (21/06/2024) and the print date in my title block after cloud printing says (20/06/2024). I'm connected to the Sydney server which is only 2hrs behind my local time so the server isn't printing on a different date to me, unless I print between midnight and 1:59am which I'm not. Any thoughts?
Cheers.
@Pat Stanford, @Lucas Story,
We don't have servers in different time zones at this time (we use a mix of in-house servers and Amazon instances). All files are processed by the same pool of servers, regardless of what the user file storage region is set to. The date is updated while publishing on the server according to the time zone the server is in. You can prevent the server from updating the date by unchecking the option to reset plug-in objects before export from the Export PDF settings dialog, accessed from the Publish dialog. The Cloud job considers all the options from this dialog when doing the processing.
