domer1322 12 Posted May 11, 2020 It seems I can't reproduce this very common roof structure and ask for your help. In the attached image, I want to make the plane of roof A be co-planar with roof surface B, as well as have that roof portion overhang a bit as shown. I understand it means that the bearing height of the wall shown with the purple line must be lower than the bearing height of the wall with the yellow line. However, when I try to reduce the bearing height of the purple wall, it will not allow me to fully lower it so that the planes are co-planar. It does allow me to lower the plane of roof A, but not enough to make it co-planar before I get an error message. I know that I can change the roof into generic solids and then make the change, but I don't want to do that, since I can't return it to being a roof object. Any help is appreciated ..... thanks Quote Share this post Link to post
Boh 459 Posted May 11, 2020 I don't think you can do it and have roof planes A & B perfectly flush using the Roof tool. If getting it almost perfect is good enough then you can do it either by: Lowering the bearing height of wall A 99.999% of what it would need to be to make the roof planes flush or using the roof overhang facility. I.e. move wall A 99.999% flush with wall B and then increase roof A overhang as required. Both ways will still leave a line between roofs A&B in hidden line and OpenGL with edges on. No line with OpenGL without edges however. These two roofs below were done using the methods above. Quote Share this post Link to post
domer1322 12 Posted May 12, 2020 Boh: thanks for the reply. I needed someone with real skill to verify that it isn't possible. I suppose sometimes the 99% technique might be OK, but I want to render it in OpenGL without seeing the line. Also, in RW the shingles don't line up. I found a not-too-complicated work around . It is a bit frustrating though ..... this roof shape is very common in my area for old ranch houses that are now being renovated. The roof tool let me down. 1 Quote Share this post Link to post
Pat Stanford 1,520 Posted May 12, 2020 The roof tool is somewhat simplistic. Often it is better to use Roof Faces so you can control exactly what you are getting. 2 Quote Share this post Link to post
P Retondo 110 Posted May 12, 2020 Boh has the geometry basically correct. To fix this: If your roof planes are not already separate objects, ungroup the roof object so that it is a set of roof planes. Then make a polygon that outlines the edges of your roof A, bearing in mind that it will extend beyond the eave of roof B as Boh illustrates. Then double-click on B, paste-in-place your polygon and add the two. Then, after exiting the roof plane edit space, join all your roof planes using the "Join" command. The roof tool isn't designed to automatically generate a roof of this shape. If you start with a polygon, it will assume that you want all your fascias to be at the same height, and will add a valley and extra plane at the intersection of A and B. You have to go through the plane editing process every time you want to create a roof like this. I always start with a simple rectangle, get a hip roof, ungroup, and edit the planes. If you do it that way, you won't usually have to join planes, they will already be aligned correctly. 2 Quote Share this post Link to post
Boh 459 Posted May 12, 2020 15 hours ago, P Retondo said: Then, after exiting the roof plane edit space, join all your roof planes using the "Join" command. I tried this @P Retondo and using the Join command on the roof planes doesn't seem to do anything. Is it supposed to turn the roof plane objects into a roof object? Quote Share this post Link to post
P Retondo 110 Posted May 13, 2020 Starting with this roof: Ungroup, draw a polygon in plan that encompases A and C up to the hip of B. Get rid of A and C and edit B to incorporate that polygon. Then you end up with this: Faces B and D do not join at a hip. To fix this, join D to B using the same "Join" tool used to join two lines Click D, click B, and get this: Quote Share this post Link to post
Boh 459 Posted May 14, 2020 Ok I understand. I got confused with the Join command in the modify menu. Thanks Quote Share this post Link to post
