TessF
Vectorworks 2020 malfunctioning
Posted (edited)
I am finding that VW2020 is malfunctioning a lot on my system. Objects shown in one place, but when selected, the highlight is offset substantially - ie more than the size of the object it self. Objects disappear off the screen, but if I do a select-all, it shows me a highlight for that object. Several other little malfunctions occur from time to time, and the program shuts itself down way more often than any previous version I have worked with. I haven't worked with 2018, and very little with 2017 or 2019, but 2016 seemed reliable and solid. I like a lot of the functions in later versions though, and am not keen to go back. But the frequency with which I find 2020 crashes or malfunctions, requiring a restart (which usually fixes the malfunction) is becoming quite problematic, and reducing my productivity substantially. Anyone else find this? Is the re a fix? I am working on an iMac with High Sierra,  10.13.6, 40GB memory and over 2.75TB available on my hard drive. Should I be using a later version of MacOS? Doing something differently?
UPDATE - other little problems:
- objects that are there and visible on the design layer, marked as visible in the viewport, but stop showing up in the viewport
- when trying to create a detail viewport: the system asks me to return to top/plan view before creating a detail viewport, when I am already in top/plan view, unrotated.
- insistence that a viewport has more than one drawing label when there is only one
Some of the issues seem to resolve when I un-rotate plan, for instance the selection offset.
If I create a new viewport showing the same portion of the plan, some of the disappeared objects will show up again - in the new and the old viewports. At least until next time.
Insert image from URL
Edited by TessF
4 answers to this question
yes, I am seeing similar weirdness, such as classes being visible when the viewport settings say it is invisible.
Check in the Vectorworks Preferences, Display pane, and check the setting for Navigation Graphics as the bottom. Try setting it to Best Compatability and see if that helps.
Thanks Pat - I am trying that and will report back. Do you know if I have to restart VW?
It seems to have resolved. Not sure whether that was it or not but I haven't had the problem for a while. Thanks!
