Christiaan Posted September 27, 2005 Share Posted September 27, 2005 The office I work for is looking into bidding for a consultancy job with the following (paraphrased) prerequisites: quote: Must be willing to install a Lotus Domino Server and Lotus Notes (v6) client on all workstations of all staff who are sharing workflow applications with the client. The client's current GIS system utilises Integraph's Geomedia Professional v5.2 as its core platform for storing the data in an Oracle 9i database. The client's staff view GIS data via a web-based system utilising Autodesk Mapguide v6.3. The GIS team makes use of both the Microstation v8 and Autocad for detailed work and 3D modelling. All data supplied must be compatible with this and thereby GIS and CAD data must be supplied in one of the following: DGN (Microstation v8 or before) DWG/DXF (Autocad 2004 or before) TEB - Mapinfo SHP - Arcview Geomedia Access Database Any data must utilise the British National Grid Coordinate System. The files should be supplied with the appropriate metadata indicating the data files structure, version and available datasets. The GIS team will supply a template for the required metadata beforehand. Considering our office consists of G5 PowerMacs, an Xserve (all running Mac OS X v10.4), Vectorworks 11, and a low-powered Windows XP laptop, what are we looking at realistically in terms of meeting these prerequisites do you think? As far as I can work out you can't get Lotus Domino for Mac so that would mean getting Lotus Domino for Windows and probably a more powerful PC than our laptop to run it. Lotus Notes is available for Mac OS X. As for 2D/3D CAD data, could we get away with the DWG export/import function in Vectorworks? I'd be a little wary of how robust it is considering the size of the client. I'm thinking we'd probably need a programmer to ensure this process was smooth enough. Also, does anyone know about REB, SHP and Geomedia Access Databases and how we might interface with these forms of data (especially via Vectorworks if applicable)? [ 09-27-2005, 09:36 AM: Message edited by: Christiaan ] Quote Link to comment
aladino Posted September 28, 2005 Share Posted September 28, 2005 We are evaluting somthing similar job, but we have great difficult to manage large vectorialized map (.dwg files). Vectorworks result a pain in zoomming and scrollig on my G5 DP 2.3 1.5Gb ram(Autocad 2000 LT result much faster on Celeron 1.2 Ghz laptop). The entry thread I've opened on Video Card on Mac is started from this issue. Quote Link to comment
Christiaan Posted October 11, 2005 Author Share Posted October 11, 2005 So does anyone know GIS, REB, SHP and Geomedia Access Databases and how we might interface with these forms of data (especially via Vectorworks if applicable)? Quote Link to comment
michael john williams Posted October 11, 2005 Share Posted October 11, 2005 When I was based in a Mac office we used software to convert your Mac into a pc - I think it was called Power PC or Virtual PC or somethink. Quote Link to comment
mclaugh Posted October 11, 2005 Share Posted October 11, 2005 Emulation may be acceptable for occasional use of a stand-alone program, but, quite apart from the issue of whether or not Lotus Dominion Server or the other required programs will even run inside an emulated environment, emulation is simply not a viable option in a network environment. Quote Link to comment
quigley Posted October 12, 2005 Share Posted October 12, 2005 Is there a technical resource at RIBA where this information is available? Alternatively a better bet may to to contact a larger surveyors company. Check out the online pages at Architect Journal - they have a pile of information and contacts. You can get a trial subscription for free... http://www.ajplus.co.uk/ Quote Link to comment
quigley Posted October 12, 2005 Share Posted October 12, 2005 Alternatively just upgrade to VectorWorks 12...... According to the pdf "Whats New Guide" it supports SHP files... Quote Link to comment
