mclaugh
Content Count
123 -
Community Reputation
0 NeutralAbout mclaugh
Rank
Journeyman
Prof Nemtschek has done more for our industry than you care to give him credit for.... 6000 post doesn't entitle you to anything Mate, what have you contributed?...you should apologised or get LOST. I would only wish for my lifetime accomplishments to read like this: http://www.nemetschek.com/en/home/the_company/people/company_founder.html Dude, for someone who pisses and whines incessantly about VW's shortcomings and how bad VW is, why don't you take your own advice and GET LOST?
Guilty as accused. Without workload, how are you going to make profit from even the USD 29? Or are you a not-for-profit organisation, eg. an OS-playgroup? The point, however, is that you can't expect NNA or those users who upgrade VW to pay for the effort to make a three-year old program compatible with the very latest operating system. The last time you contributed funds to the development was three years ago. You could have participated two years ago and a year ago, when there was no recession. The subscribers, so to speak, have contributed annually and can, I would say reasonably, expect those funds to be used for new and improved features. (When do we want those? Now!) It's because ASSHATS like you just bend over and grab your ankles every time NNA decides to ream its customers again that NNA continues to release bloated, bug-infested beta-ware rather than expend even minimal effort toward fixing existing bugs. Enjoy the rape job, 'cuz there's a lot more where that came from.
VW 2009 and upcoming Mac OSX 10.6 Snow Leopard
mclaugh replied to AN Design's topic in General Discussion
Given that 2009 does not run without problems under ANY version of Leopard, it is extremely unlikely that it will run without problems in Snow Leopard. -
Error 2010
H.264 produces very high quality video, but requires significantly greater processing power to encode than most other formats. As a point of comparison, a 5:30 (mm:ss) walkthrough that took 11:36 (hh:mm) and change to render on my 2.0GHz PowerMac G5 Dual using Sorenson 3 required 22:56 (hh:mm) and change to render using H.264 on the same computer. (No other programs were running on the computer during either render, and the computer was rebooted immediately prior to running each render.) I find Sorenson 3 "good enough" for most of the animations I do. YMMV.
HEAR! HEAR!
Computer crashed & now VW2008 files think they are still in use...
mclaugh replied to lwaIT's topic in Architecture
Pretty basic question, but since we're troubleshooting ... I presume you searched for the .lck file on both the server and the local disk? Since you mentioned Terminal, I also presume you searched for the file using something other than Spotlight (which, IMO, is less than useless)? Temporarily save a copy of the problem file under a new name. Connect a laptop to your server via Firewire then reboot the server as a Firewire drive. When the drive mounts on the laptop's desktop, navigate to the problem file(s) and delete it (them), then transfer the temporary copy to the server HD and rename it to the name of the original file. If OX S squawks about not being able to delete the file, hold down Option" and select "Secure Empty Trash" in the Finder window. -
And that proves what? I have astronomer friends modelling planetary systems who page out 64GB of RAM on a daily basis.
Um ... according to the OP, he's been requesting it for 15 years ... seems like it should have been addressed by now ...
Really? You need to register to view all online forums? Maybe I'm on a different internet, 'cuz I regularly hit about two dozen different forums, and ain't none of them require me to register to view them: to post or download, yes; but not to view. The only sites I've heard of that require someone to register before viewing the content are pR0n sites. You mean OTHER than the fact that you're "sharing" (selling) user information?
Massive problem with corrupt files pls help!!!
mclaugh replied to alexwoody's topic in General Discussion
Ok. Again, DEEP BREATH. The data is PROBABLY still there, it's just been decoupled from the file database, so there is a reasonably probability that the file(s) can be recovered. (Alex, if the guys at the alleged mac shop did not recommend a file recover program, they're a bunch of idiots.) Before doing ANYTHING else, go out and buy a boxed copy of Data Rescue II or File Salvage (do NOT download it or you risk overwriting the missing data), and beg, borrow, or steal an external HD to install it on and to copy any recovered files to. In this case, I would recommend Data Rescue II because it comes with an emergency boot CD. Whatever you do, DO NOT install it on the HD that has the corrupt file or you may overwrite part of the missing data. If you are not running from the emergency boot CD, install the program on the external drive, launch it and run a comprehensive deep recover scan. This WILL take several hours, depending on the size of your drive. When it's done, you will be presented with a list of several hundred/thousand files with descriptive names like, "File xxxx", "Picture yyy", "Document zzzz," etc. At which point, you have to go through the list opening up likely candidates until you find the files(s) you're after. (You can skip a lot of files based on file size.) Good luck. -
Um ... OS X 10.5 is Leopard. Panther was 10.3. Does VW2008 even run in Panther?
Get rid of the Attributes Palette.............Altogether
mclaugh replied to Chris D's question in Wishlist - Feature and Content Requests
Did you bother to read any of the other posts? Every freaking word of every freaking post, and the argument for eliminating the Attributes palette boils down to, "WE don't use it around here, so nobody else should use it either." -
SPHERIC quicktime pano
mclaugh replied to blimey's question in Wishlist - Feature and Content Requests
Um ... don't File > Export > Quicktime VR Object and File > Export > Quicktime VR Panorama already do that? -
Word! If you don't like the Attributes palette, unselect it in the Windows menu.
