I'm using 2020, is there a faster way to add window id labels than clicking each window to open the settings?
I've found that I can add a ID label in the object info palette under data but it doesn't update the label on the design layer until you double click the window and then click ok.
If you look at the two screen shots you can see I added the id label in object info but not on the actual window. When I get into the window settings this new label is there. Any time saving tips with this would be helpful.
Daniel s
1 answer to this question
