blimey Posted July 5, 2005 Share Posted July 5, 2005 Help! I've spent the whole day (and night) trying to find a way to update classes : We're working with workgroup reference and many files created from the same template. We use class style at creation so to have a coherent presentation throughout the files. Quite of few classes have been change in the Template (color, line width and pattern) although their names remain unchanged... Is it possible to update the classes of all the files to match the template's classes new color and other attributes? I can't imagine to do it manually for each of the files...!!! Lot of thanks to all of you. Quote Link to comment
Vectorworks, Inc Employee Bruce Ferguson Posted July 5, 2005 Vectorworks, Inc Employee Share Posted July 5, 2005 There isn't a way to do that yet. The ability to change a class in a file and then have the class definition updated in all files that workgorup reference the file is being considered for a future version of VW. Quote Link to comment
blimey Posted July 5, 2005 Author Share Posted July 5, 2005 OOHH :-(... No other way in the meantime? Thanks anyway for replying. Quote Link to comment
G-Pang Posted July 6, 2005 Share Posted July 6, 2005 Make sure there is an option / preferences setting to let user choose which way they prefered. Do not repeat the same problem as group default class does. - very hard to turn off specific class. Let us choose which way is suit us most. G-Pang Quote Link to comment
MullinRJ Posted July 6, 2005 Share Posted July 6, 2005 Imt, I don't presume to know all the particulars, but I would think a VectorScript might address your problem. You'd have to execute the script in each file that needs updating, as a script cannot be run across multiple files at the same time, but that would still be easier than doing it manually. Try posting your question in the VectorScript section of the board. You might be able to export your good file as VectorScript and copy most of the code you need from there into a new script file. I'm sure someone can guide you to the right area of the VectorScript file to get you started. Raymond Quote Link to comment
blimey Posted July 6, 2005 Author Share Posted July 6, 2005 Thanks Raymond, I'll try the VectorScript section. Quote Link to comment
Dragonetti Posted December 1, 2023 Share Posted December 1, 2023 @blimey Hi, did you ever find a solution to this problem? Cheers! Quote Link to comment
